Novice Q. Changing 4AGZE S/C Belt
Postby beeker » Mon Aug 15, 2005 8:46 pm
So I need to replace the cracking S/C belt on my 4AGZE.
I have loosened off the centre lower ~guide pulley (it runs on a guide slot for tension). It logically looks like it should fall downwards, taking slack off the belt. It wont though, perhaps seized.
I've given it a light wack, but want to ask if this is correct prior to the big wack. I assume you don't have to loose this guide pulley from the front (centre of pulley wheel)
Any tips ?
thx in advance.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Mr Revhead » Mon Aug 15, 2005 9:14 pm
you sure do, loosen off the nut on the front
Postby beeker » Mon Aug 15, 2005 9:15 pm
fixed it.
You have to loosen the centre bolt on the guide pully wheel.
I'm learning !
06 RS4 Avant
beeker
