oil pressure...100psi 20v yeah right
Postby gazza_jay » Mon Aug 15, 2005 9:23 pm
Ive hooked up a oil pressure gauge... im sorta worried bout how much pressure my 4age 20v has at bout 7500 my car passes 100psi is that ment 2 happen shouldnt it b a lil lower... I know vvt runs on a oil pressure solinoid does that increase much oil pressure. ive cleaned the pcv valve. it has the usual smoking 4 a 4age when u kane it. and the vvt pully is rooted lol and ideas would help... hm hopefully supercheap give refunds lol
gazza_jay
Postby Lloyd » Mon Aug 15, 2005 9:32 pm
You been thrashing it when its cold? My cold oil pressure on a GZE was about 60psi at idle and up to 80 or so with a bit of revs when cold. Dropped to about 20ish at idle when warm and not much over 50 when driving from memory.
Postby NZ_AE86 » Mon Aug 15, 2005 10:12 pm
I would not be too concerned about it, there are alot of factors. But this is not really too high. It is in the upper scale though!!
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby YeMs » Mon Aug 15, 2005 10:30 pm
does that gauge use a sender or does it feed oil to the gauge?
Your local Hybrid Elite tech
YeMs
Postby gazza_jay » Tue Aug 16, 2005 9:16 pm
yea its run off a sender unit. and the reading is when the car is up 2 operating temp... if im cruising round town it varies from 40-60 when warm. i know it will read higher when cold. its just when you put ur foot down oil pressure goes past a hundy pretty quick oil level and all that r good.
gazza_jay
Postby 85AW20v » Wed Aug 17, 2005 12:18 pm
If you vvt pulley is stuffed then the buildup that has caused that may also be causing your oil pressure relief valve to be stuck shut which could cause the high reading. Sometimes you can get your vvt pulley working again by taking it to a reconditioners and leaving it in their acid bath for a week - cleans all the crap out from inside them.
See ya
Simon
85 MR2 20v
85AW20v
Postby Blkwinter » Wed Aug 17, 2005 12:36 pm
Mine reads inbetween 80-100psi when reaching over 6000rpm
Blkwinter
