Otomo wrote:pidge wrote:(over simplified)
Get a 7afe block and conrods and swap it for you 4a block and conrods.
1800cc-ish - and can be turboed with lower compression pistons (e.g. 4agze pistons)
Yeah, but the issue here would be what ECU to use. Or you'd have to map an aftermarket ECU for this.
Like I said, over simplified. Somebody has done a turbo 20V 7AGE IIRC (search!)
Keep in mind, modifying a car == $$$$, one way or another. A previous poster has pointed out that 0.5mm overbore is the most you would manage on the 4A block, which would give you about 15cc more overall (whopdedo). Other options are a 3SGE ("straightforward" from the point of view of engine stuff, but potential cert problems due to the engine mounts) transplant or a 7AGE (I don't think it would need different engine mounts (both a "A" blocks, but you'd need to sort out an ECU).
And in both cases you would have insurance hassles.
Want more grunt that a 20V 4AGE? Go get a 3SGE powered Curren / EXIV / Altezza etc - or a Caldina GT.
A Golden grule of car modification is to not waste time and money "upgrading" a down-spec car to a high spec car (e.g. Levin SJ modded up to a Levin GT Apex - buying the GT Apex will be a lot less pain, time and money). You just end up with a certification and insurance headaches. All you would get with buying the higher spec level car is insurance headaches - but less that that of a modded car.
Another example is the Impreza WRX to STI. Save your pennies and buy the STI. At least you won't be going through the Upgrade/raise boost on turbos, blow clutch, upgrade clutch, blow Gearbox or diff. Rinse, repeat.
An exception to this would be for a classic car (e.g. AE82/85/86) where it is not feasible to get your hands on an original example any more, and you are prepared to spend the $$$ to bolt the upspec bits onto the common body.
Trust me, be there, made that $15000 mistake, OK?
