your going to have many problems! I get so many pms about this I have done this in a few rwd's, I like the 20v as they are cheap and go not to bad.
First get a cross member out of an ae85 and some rwd 4ag mounts so you can drop the engine in.Then you'll need to find a k50 out of an ae85 or a t50 and a bellhousing out of an rwd A series car (carina corona ae86 etc). Use a rwd backing plate make sure you put in a spigout bearing in and use what ever 4age flywheel you have(do a search for k50,t50 info if you need it).
Next you'll have to decide what to do with the dizzy and thermostat housing which want to sit in your firewall. The easiest is to just bash the hell out of your firewall. I made a dizzy relocator but dont have time to make any more at the moment. The thermostat housing sticks out the most so you can use a rwd water pump and re-route the flow I've done this so pm if you need a hand. If its a silvertop you will have to create a plenum chamber or mod the factory so you can use the afm and idle up. The wiring is simple you just have to lengthen a few and chop a whole lot out check out
http://www.club4ag.com for pin diagrams.
At the moment i run a megasquirt and coil packs which saves alot of hassle. I have left alot of stuff out so ask as you get there, im taking a bunch of pics and hopefully going to make an faq on this stuff
