Logan wrote:ive got a factory toyota rebuild manual, what excatly do you want to know?
Logan wrote:you should be able to go shop and ask for 2tg bearings and they can look it up in catalogue, but i suggest doing a quick google seach and downlaod the ACL bearing catalogues, so you can just list part numbers to your suppliers.
I just rebuilt my 3tgte and the rings are the same as some mitsi...cant remeber...
I'll get the actualy nubmers for you tongiht ojk..
Sweet
Logan wrote:also,
connecting rod thrust clearance 0.16-0.26mm standard 0.3mm max
crank thrust clearance 0.02-0.22mm standard 0.3mm max
bore diam 85.00-85.05
piston diamter 84.94-84.99
ringend gaps,
n01 0.25-0.56
no2 0.20 -0.51
oil 0.30-0.78
ring groove clearance
n01 0.20-0.60
no2 0.015 -0.055
oil 0.015-0.060
enuf numbers for now
Logan wrote:if the rods are still connected to the pistons, they should be numbered, from factory if you need anything else let me know. make sure you find the arrows on the piston to point fowards also.
sleeektoy wrote:I know the redline is @ 7000 for the early 2T-G's, yellow kicking in at 6500.
I dont know the limits for the later EFI engines but i assume they're the same.
I regularly have mine up to 7500rpm on the racetrack, just gotta watch the cam chain tension as the chain tends to hit the cam cover if not correct at those rpm's. Changing the chain regularly alleviates this problem.
fuel wrote:Logan wrote:if the rods are still connected to the pistons, they should be numbered, from factory if you need anything else let me know. make sure you find the arrows on the piston to point fowards also.
I've just finished cleaning the pistons, and the only numbers I could find on the rods were 188 M, which 3 had, and the other one had 188 U. Two of the rods had '2' on the bearing caps and '4' on the piston, and the other 2 had '3' on the cap and '3' and '1' on the piston.
So I can't identify which piston is which.. great. I guess this means I will need to rehone the cylinder bores and fit new rings?
