4afe + boost?
4afe + boost?
Postby the fallen303 » Wed Sep 21, 2005 1:03 pm
just curious, i have a 4afe in my 93 rolla. i also have access to a ct12 off a 1g-gte, and a brother that can weld with the best of them. now what i'm wondering is the ecu for the fe is map based, can it handle positive air pressure, and fuel accordingly, or can the map sensor and ecu only handle up to 0psi? i'm not after anything flash or fancy, so if this won't work, it's no biggy, just something for shits and giggles basically. i'm not looking at doing a ZE conversion, or new ecu or anything, as can't be bothered, if this will work, sweet, if not, meh, who cares.
so, will it?
true house of JZ
Stay true to the origin
the fallen303
Postby crnkin » Wed Sep 21, 2005 1:05 pm
in short, it will work on relatively low boost (6 or less) the specifics, im not so sure on, but a ct12 is nice n small and should be fine
deaf_homo "currrently yes"
crnkin
Postby ants_ae92 » Wed Sep 21, 2005 2:49 pm
here is a great thread and a similar setup on a 5afe
http://forums.toyspeed.org.nz/viewtopic.php?t=31816&highlight=
Similar to what I will be doing to my 4age.
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
