W55 box right for 1ggteu?
Postby HELBND » Wed Sep 21, 2005 2:40 pm
hey as the topic says, im looking at converting my ga70 from auto to manual, and i was just wondering what sort of box would be best, and what bellhousing
Ben
HELBND
Postby Silent Knight » Wed Sep 21, 2005 3:09 pm
Bellhousing is easy...you need W>G!
As for the box...you want a W series box with a rear shifter..not mid or front shifter otherwise you'll have to cut out your console to make it fit through properly...
Silent Knight
Postby HELBND » Wed Sep 21, 2005 3:16 pm
awesome cheers-wasnt quite sure about bellhousings, as have never really worked with rwds before
HELBND
Postby spencer » Wed Sep 21, 2005 4:19 pm
Dont let ayone charge you much for a bell housing either they are common as.
spencer
Postby myk00l » Thu Sep 22, 2005 8:28 pm
ke70wagon20v wrote:Dont let ayone charge you much for a bell housing either they are common as.
Depends. If it's a 1G-EU bellhousing it's not worth much. But be prepared to pay more for a 1G-GEU or 1G-GTE bellhousing as the 1G-EU bellhousing has clutch fork and slave cylinder on exhaust side, which you don't want as the exhaust may heat the clutch fluid and make the clutch hard to use or not work at all. The 1G-GEU or 1G-GTE bellhousing has clutch fork and slave cylinder on the opposite side.
myk00l
Postby Silent Knight » Fri Sep 23, 2005 7:00 am
None of the housings are really worth much. I paid 10$ for my 1G-GTEU housing. Just have to do a bit of hunting.
Silent Knight
Postby KE20 » Sun Sep 25, 2005 5:12 pm
also th 1c and 1s and 3t bells fit aswell, except one bolt(can be slotted to line up) up top, but locate fine, so thats 4 different engine bells, generally with the option of clutch fork on either side so thats at least 8 different bells to choose from.
KE20
