20V Air intake
20V Air intake
Postby Armourermike » Tue Sep 20, 2005 6:32 pm
Am looking at upgrading me standard air box. Will a pod filter in the engine bay give me more power? Or should I fit a cold air box? :?
Armourermike
Postby bad20v » Tue Sep 20, 2005 7:47 pm
Heres just an example of the cold-air box I built in my BZR....
A pod filter in a cold air box will work better than just a pod filter in a hot engine bay. As to how much Hp you will gain? Put it on a dyno before you do it, then build your cold air box/ pod filter combination and dyno it again. :D
Thank-You.
bad20v
Postby Loudtoy » Tue Sep 20, 2005 9:50 pm
Or you could use your search button and find all sorts of things on cold air intakes - plus it will help if you spesify which chassies your motor is siting in as they have different shapes, different motors and altogether different ways of getting a nice efficient cold air intake to fit it!
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby bad20v » Wed Sep 21, 2005 11:33 am
Loudtoy wrote:Or you could use your search button and find all sorts of things on cold air intakes - plus it will help if you spesify which chassies your motor is siting in as they have different shapes, different motors and altogether different ways of getting a nice efficient cold air intake to fit it!
He's got a Toyota Carib w/blacktop 20v engine. So that why I posted those pics. (I read some of his other posts.) :D
Thank-You.
bad20v
Postby Andy » Wed Sep 21, 2005 1:00 pm
You could buy my setup and build a cold air box... :D
http://forums.toyspeed.org.nz/viewtopic.php?t=36674
But yea... definitly build a cold air box otherwise you are wasting your time and money on the pod.
from Andy
Andy
Postby Armourermike » Wed Sep 21, 2005 6:23 pm
Im planning on doing this mod. Will get it dyno'd before and after. Will let you all know how it goes and will show you the pics when its done. Wont be untill late October tho :wink:
http://4age.net/tech/coldair.htm
Armourermike
Postby Mr. Mainstream » Wed Sep 21, 2005 7:36 pm
hay bad20v that airbox would look mint if the battery was in the boot not in front of the pod
Current:77 MK2 Ford Escort L 1.3L
75 MK2 Ford Escort L 2.1L
Had: 2X Early Subaru Leggys GT Wags, 1X Subaru RS, 1X 2004 Subaru B4, 2x BFMP Turbo Sedan Famil's, 2x BFMR Turbo Sedan Famil's, AE92 FX-GT, 97 Holden Calais 3.8L
Supercharged 12psi ,Escort, BZ-R
Various Others
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Mr. Mainstream
Postby bad20v » Fri Sep 23, 2005 12:28 pm
Mr. Mainstream wrote:hay bad20v that airbox would look mint if the battery was in the boot not in front of the pod
Yeah, but I'm lazy and haven't shifted it yet. :P
Thank-You.
bad20v
Postby Mr. Mainstream » Fri Sep 23, 2005 2:07 pm
i still think this is the best "Air intake" idea
Various Others
Mr. Mainstream
Postby bad20v » Fri Sep 23, 2005 2:15 pm
Maybe with the bumper on! Otherwise you would get alot of water and road crap on your filter!! :lol:
You would be suprised how much air flows behind your headlights, and with a setup like mine, it keeps the air box pretty damn cool. When I'm racing I just have to remove the headlight, takes like 2mins, and that gives even more flow. :D
With a setup like in the pic above, its a bit harder to get to your filter to wash/clean it. I just have to lift my bonnet and undo a few screws and its out. :D
Thank-You.
bad20v
Postby Mr. Mainstream » Fri Sep 23, 2005 2:26 pm
bad20v wrote:Maybe with the bumper on!
8O
Various Others
Mr. Mainstream
Postby pervert » Fri Sep 23, 2005 2:31 pm
Stop showing off that $&#$% awesome car, you don't have it anymore!!! :lol:
pervert
Postby Mr. Mainstream » Fri Sep 23, 2005 2:39 pm
pervert wrote:Stop showing off that $&#$% awesome car, you don't have it anymore!!! :lol:
you love it :lol:
Various Others
Mr. Mainstream
Postby pervert » Fri Sep 23, 2005 2:45 pm
I want it more like... :cry:
pervert
