INSTALLING VACUUM GUAGE ON AE101
Postby jamex316 » Fri Sep 23, 2005 2:16 pm
CAN ANYONE HELP? I'VE GOT AN AE101 20V 4AGE THAT HAS THE VACUUM GUAGE HOOKED UP TO ONE OF THE THROTTLE BODIES. THE GUAGE FLICKS, SO DOES ANYONE KNOW HOW TO LINK ALL THE THROTTLE BODIES TOGETHER OR TO MAKE IT WORK SOMEHOW?
jamex316
Postby fatgtr » Fri Sep 23, 2005 2:55 pm
FIRST OF ALL YOU HAVE TO TURN OFF YOUR CAPS LOCK.
from what i understand on your post you are saying its not working properly, is it before or after the throttle bodies, this is what you need to do.
just find a place on the inlet manifold BELOW ALL the throttle bodies, and it should work fine
if its installed correctly maybe there is something wrong with your gauge or motor
James
gotta love the punk music
fatgtr
Postby jamex316 » Fri Sep 23, 2005 3:04 pm
whats the caps lock?
the guage is hooked up to the left hand side throttle body.
jamex316
Postby Mr Revhead » Fri Sep 23, 2005 4:05 pm
i think t-ing it off the fpr line is where you want it
Postby Caveman » Fri Sep 23, 2005 5:44 pm
Caveman
Postby AJz » Fri Sep 23, 2005 6:56 pm
^^^^^ BAHAHAHHAHAHAHHAHAHAHA, post of the day right there peoples :lol: :lol: :lol: :lol: :lol: :lol:
I had vtax :(
AJz
Postby IH8TEC » Fri Sep 23, 2005 6:59 pm
:lol: that is farkin funny right there, top effort :lol:
Postby sergei » Fri Sep 23, 2005 7:50 pm
No DON'T use FPR line to connect, it will flicker there, use T on one of the hoses on right side of intake manifold where there are 1 fat hose, 2 thin hoses, little bit to the right from PCV hose, basically you will see the round plug on top.
Postby Mr Revhead » Fri Sep 23, 2005 7:55 pm
or i could be wrong :lol:
sorry, have a look and see, shouldnt be to hard to find the one he means, comes off under the balance bar (funny looking fuel rail thats not a fuel rail)
Postby AceSniper » Sat Sep 24, 2005 2:46 am
yea fpr only runs off one cyl :o
its down the other end by the fat hose slightly infront and more to the left of the last injector on that side
AceSniper
Postby AceSniper » Sat Sep 24, 2005 2:50 am
AceSniper
Postby strap-on » Sat Sep 24, 2005 10:07 am
if you can see ace snipers pic it works thats where i put mine from memory
strap-on
Postby EssDub » Sat Sep 24, 2005 12:26 pm
On every toyota i have seen, there are a few (3 or so) vacuum lines coming off the runners JUST before entering the head. Its a pity you aint MAP operated or you could go tap into the MAP line :mrgreen:
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
