mr2 billstien shocks
Postby MR2MAD » Fri Sep 23, 2005 8:51 pm
this is one for you mr2 pro's wat colour are the factory billstien shocks in a mr2 cos if found a second hand set of billstiens on a mr2 but im triing to find out if they r factory ones or aftermarke cheers
MR2MAD
Postby Mr Revhead » Fri Sep 23, 2005 8:57 pm
yellow
Postby fivebob » Fri Sep 23, 2005 9:03 pm
Mr Revhead wrote:yellow
Nope, they're black, with a small yellow sticker.
Postby Mr Revhead » Fri Sep 23, 2005 9:07 pm
:?: in that case the replacment ones are yello
Postby TRDWGN » Sat Sep 24, 2005 1:41 pm
FWIW last time i checked Autolign were unable to service the factory MR2 Bilsteins so keep this in mind if the set you found need servicing
TRDWGN
Postby Dell'Orto » Sat Sep 24, 2005 5:18 pm
Are you sure thats the case for all of them? Cause I've seen a few in wreckers, and they were definately yellow with the blue bilstein sticker.
Postby Akane » Sat Sep 24, 2005 5:20 pm
Mine is black with a small yellow bilstein sticker on it.
Postby fivebob » Sat Sep 24, 2005 6:16 pm
Well for all the ones I've seen, which are my 1994 GT-S (2 of them), my 1996 GT, and several others I've looked at. So at least up until 1996 they were black from the factory.
Postby Dell'Orto » Sat Sep 24, 2005 8:09 pm
Quite odd...the ones I've seen in wreckers were pre 93, maybe they changed for the later ones?
Postby fivebob » Sat Sep 24, 2005 8:13 pm
Mmm, Boost wrote:Quite odd...the ones I've seen in wreckers were pre 93, maybe they changed for the later ones?
More likely the ones you've seen where replacements, all the ones I've seen on Tau were black, and that's quite a few of them. As Mr Revhead has said the current supply is yellow, and from what I've seen don't have the Toyota logo on them.
