AE92 GTZ rear hub question
Postby crispy'86 » Sat Oct 01, 2005 4:06 pm
Does anyone know if the rear hub assembly on an 1988 ae92 GTZ is the same as a normal ae92 trueno or levin?? Just went to do bushes and they wrong, thinking if i can use the hub off my other car it'd be alot easier.
Other car is an 88 ae92 levin with tems (not that i'd imagine the tems would make a difference.
Both disc rear end and both 4age models
And would like to know if anyone has put the rear hub assembly onto an ae82 fxgt
crispy'86
Postby ATAl » Sat Oct 01, 2005 6:11 pm
I'm pretty sure they are the same, just test fit your other one, they're easy to remove / install.
ATAl
Postby soopachargen » Sat Oct 01, 2005 6:56 pm
My ae91 fx had ae92 supercharged levin hubs on it and iv just swapped one of them for an ae92 fxgt hub... they were identical.... hope that helps
When in doubt, down and out.
soopachargen
Postby crispy'86 » Mon Oct 03, 2005 5:46 pm
cheers people, thanks for your help
crispy'86
