Whats Your Revs To Speed?
Postby EVL GSXR » Mon Oct 03, 2005 6:46 am
Accord sit's round 2,500rpm at 100kph..
GSXR sit's round 5,500rpm at 100kph :D but rev's for another 9,000rpm :lol:
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Postby Inane » Mon Oct 03, 2005 9:07 am
my falcon used to Idle @ 650, would cruse along at 110 @ around 1400rpm... and rev out to a gigantic 6000 RPM !!!
Inane
Postby Santa'sBoostinSleigh » Mon Oct 03, 2005 2:35 pm
my caldinas theoretical top speed 265kph!
110kph ~ 3000rpm in 5th
however i seem to perfer driving in 3rd and 4th so that the revs are slightly higher ;) :twisted:
in 50k zones im almost always in 3rd, cruising in a 80+ zone would be in 5th
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Re: Whats Your Revs To Speed?
Postby V8MOFO » Mon Oct 03, 2005 2:39 pm
Muzzie wrote:
V8MOFO wrote:muzzie, you need petrol!
No I don't, it's still 1.8 of a tank from empty, and then once it reaches empty the light comes on and it does another 70 odd km :P
hay this was very similar to my soarer, except when you had just filled it up it had 70 odd km left, not like yours from empty :P
Nah, I think mine used to sit at about 2800rpm in 4th
my corolla used to sit at about 4500rpm :lol:
Anger is seldom without argument but seldom with a good one.
Image Fact of the day: I have only updated my fact of the day on time, Three times.
V8MOFO
Postby bad20v » Mon Oct 03, 2005 2:41 pm
3000rpm @ 100kph in 6TH GEAR!I love close ratio's!!! :lol:
Thank-You.
bad20v
Postby Bling » Mon Oct 03, 2005 3:29 pm
3100ish rpm @ 100
5th gear... looks like 6th gear box would save me heaps ;)
Postby Santa'sBoostinSleigh » Mon Oct 03, 2005 4:14 pm
i wouldnt mind a 6 speed in the caldie, closer ratio and all of course :)
Santa's Mega Sale
Postby bad20v » Mon Oct 03, 2005 4:17 pm
I actually wish the 6th gear in mine was a wee bit longer, say 100kph @ 2500rpm. Mite be a bit cheaper on gas. :D
Thank-You.
bad20v
Postby Distrb » Mon Oct 03, 2005 4:21 pm
In the tezza @ 100kms in 6th its a smidgen under 3000rpm... so at a guess 2800/2900rpm..
havent driven the rolla for quite some time, so cant really say at this point in time...
Distrb
Regular Poster
Postby bigfut » Mon Oct 03, 2005 6:22 pm
the tezza is about 2800ish, the hiace does exactly 96km/hr at 3,000 so yeah
http://toyspeed.blakjak.net/profiles/profile.php?id=1702
The Harder You Fall The Higher You Bounce!
bigfut
Postby RS13 » Mon Oct 03, 2005 7:16 pm
I hear ya Chelles! My vt4k Honduh does 3800 at 100km/h, which sounds damn hard on the motor, but I'm used to it now. It seems very high, but then, the redline is 7000rpm, which is also peak torque, and limits at 8200rpm.
RS13
Postby Dragger_Dan » Mon Oct 03, 2005 7:32 pm
About 2700 @ 100 in the AW11. Sadly that's with higher profile than standard tires on the back, so I'll probably loose a bit of economy when I put proper tires on it.
Dragger_Dan
Postby NA Drifter » Tue Oct 04, 2005 1:06 am
My ae86 does around 3500rpm@ 100km/h
TE71 3100rpm @100km/h
both at 5th gear 185/60 14 tyres
I think mainly AE86 got 4.3:1 final diff ratio and TE71 got 4.1:1
Keith
NA Drifter
Postby event2 » Tue Oct 04, 2005 10:22 pm
my phat ae82 corolla sedan with 4a motor and smooth auto gear box does 3000rpm at 100kmh in drive. has worse fuel economy than my gtz and costs just as much to fill up on cheeper 91.
1991 gtz trueno "HELL YEA" 4 sale (sold and i miss it so)
event2
Postby XERO » Tue Oct 04, 2005 11:28 pm
My Caldie will do it at 2600... (GT non turbo)
Altezza RS200 Z Edition
For performance parts :: www.drivenperformance.co.nz
XERO
Postby riddles » Wed Oct 05, 2005 5:48 pm
My ST205 does 100 at 2600rpm, although I think my rolling diameter may be out by 2 or 3%. When going past those trailers that tell you your speed they seem to read either 51 or 52 with the needle exactly lined up with 50. Not that you get up to 50 much round the Wellington CBD :lol:
riddles
Postby no_8wire » Wed Oct 05, 2005 8:17 pm
Dragger_Dan wrote:About 2700 @ 100 in the AW11. Sadly that's with higher profile than standard tires on the back, so I'll probably loose a bit of economy when I put proper tires on it.
REALLY? mine about 3000-3200 at "around" 100
no_8wire
Postby Dragger_Dan » Wed Oct 05, 2005 8:45 pm
yeah, I'm running 195/65R14 on the back, so I've got a bit more rubber to turn.
Dragger_Dan
Postby no_8wire » Wed Oct 05, 2005 9:10 pm
who would have thought 5mm could make that much difference...Im running 195/60/14....
no_8wire
Postby Dragger_Dan » Wed Oct 05, 2005 9:37 pm
http://www.csgnetwork.com/tireinfo4calc.html
Don't forget the original AW11 tire was 185/60/14. So if you compare mine with that then there's quite a difference. According to that calculator you speedo would have an 8 km/h difference to mine. And with original tires I would have a 12 km/h difference from standard. If I understand it correctly, the aspect ratio is a percentage of the width of the tire. Therefore changing both the aspect ratio and the width would result in this bigger difference.
Dragger_Dan
