Differences between blue top TVIS and red top TVIS/non-TVIS
Postby ChaosAD » Sat Sep 03, 2005 4:59 pm
I had an ae82 fxgt that was first registered in mid '87. and this had a bluetop with the 40mm bigends etc like all the other ae82 fxgt's. But it had a 7 rib block and a few other little bits that dont belong on a bluetop, but it still all looked standard
ChaosAD
wats mine
Postby escortman » Sun Oct 02, 2005 6:07 pm
i have a AE82 fx it has tvis but i dnt no if its red or bluetop as the writing isnt coloured, where are these ribs ppl r talkin about
escortman
Postby Alex B » Sun Oct 02, 2005 6:23 pm
AE82 is bluetop.
Postby escortman » Sun Oct 02, 2005 6:26 pm
so all ae82s r bluetop ?
which engien is better
escortman
Postby Stealer Of Souls » Mon Oct 03, 2005 8:22 am
Yeah. As far as I'm aware, out of the factory al AE82s are blue tops.
The non-TVIS redtop (smallport red top) is the better NA engine.
As for the ribs, they can be seen on the side of the engine opposite to the oil filter (did that make sense???!!).
Here's a question.
If ChaosAD has a 7rib block with bluetop internals, does that mean that you can put blue top internals into any 4A block?
'86 AE85.5 Levin
Stealer Of Souls
Postby ee904age » Mon Oct 03, 2005 5:42 pm
Stealer Of Souls wrote:
Here's a question.
No. I cant give an explanation for his engine, but Bluetop internals SHOULD only fit in 3 rib blocks, such as 4A carb, 4AFE and of course a bluetop.
Other than that, most parts are interchangable. My engine has a TVIS Redtop block, Silvertop 20V rods and Pistons, a bluetop head with TVIS redtop cams. You could say its a mongrel :oops:
Oh and on a side note: My TVIS redtop cams have 7.1mm lift, measured on a lathe with a DTI.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Mr Revhead » Mon Oct 03, 2005 6:21 pm
if you swap the crank, rods and pistons you can use any 4age internals in any 4age block
Postby ee904age » Mon Oct 03, 2005 6:45 pm
Doesnt the Bluetop have smaller mains than the rest though?
90 SW20 N/A - Sold
ee904age
Postby Mr Revhead » Mon Oct 03, 2005 6:50 pm
no, smaller big ends
Postby escortman » Mon Oct 03, 2005 8:24 pm
so which is the best motor
escortman
Postby AE85coupe » Mon Oct 03, 2005 8:33 pm
standard? the smallport non-tvis or the bluetop are the best
the redtop tvis = shite
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby crnkin » Mon Oct 03, 2005 10:36 pm
AE85coupe wrote:the redtop tvis = shite
has excellent comp ratio for turbo, super strong gze sized rods (except with no flat machined "plain" on the bigend), and gze crank. but it is "shite".
it has however the lowest ("shite") stock power rating, but you wont feel it seat of the pants.
deaf_homo "currrently yes"
crnkin
Postby Drifter4ag » Tue Oct 04, 2005 12:37 am
i would agree with the SHITE comment for redtop tvis .. .
sure it has semi large rods and large crank
but you dont need these ..
bluetop is the best for turbo madness with low boost .. small port redtop is best for madness n/a ... all the rest are horrible.
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby Stealer Of Souls » Tue Oct 04, 2005 8:55 am
Okay... Getting a little confused now...
So you can you put (for example)...
Blue top crank
Blue top rods
Blue top pistons
Blue top head
All into a (shite) redtop TVIS block?
This is what I scavenged to learn to rebuild engines from...
Can you change to say small port red top pistons?
'86 AE85.5 Levin
Stealer Of Souls
Postby Mr Revhead » Tue Oct 04, 2005 9:20 am
yes to the first bit.
to use the redtop pistons u need to use the redtop rods, which means the redtop crank.
or machine out the gudgeons to take the 20mm size used in the later engines
Postby crnkin » Tue Oct 04, 2005 9:37 am
Stealer Of Souls wrote:Okay... Getting a little confused now...
Blue top crank - NO
Blue top rods - NO
Blue top pistons - NO
Blue top head - YES
[/b]
crnkin
Postby Mr Revhead » Tue Oct 04, 2005 9:41 am
crnkin, thats incorrect
Postby crnkin » Tue Oct 04, 2005 11:21 am
Drifter4ag wrote:correction ..
redtop tvis has 42mm .. so large crank ..large rods ..large bearings .. 9.4:1 bluetop pistons with 20mm pin
really
crnkin
Postby Mr Revhead » Tue Oct 04, 2005 11:28 am
yes, blue tops have 18mm pins.
he prob means to machine them out to 20mm.
if you put ALL the bluetop bits into the block, itll work
Postby Stealer Of Souls » Tue Oct 04, 2005 1:52 pm
Okay... Got it...
So all use ALL blue top stuff in any block.
Or you can use a combo of any..
smallport redtop
silver top
black top
atlantic spec
bits in a block.
Okay. So just poked myself in the eye with another question.
Can you put anything in a bluetop block? Or only bluetop internals?
'86 AE85.5 Levin
Stealer Of Souls
