Mmm, Boost wrote:Interesting, I wonder if my TVIS is actually wired up...does anyone have a link to a page on how to test it?
Look at your dyno plot it should spike like mine.
If they werent operating it would be as slow as the ke70.
l1ttle_d3vil wrote:Mmm, Boost wrote:Interesting, I wonder if my TVIS is actually wired up...does anyone have a link to a page on how to test it?
this should tell you what you want. http://www.hachilife.com/garage/?manual=em_45
thanks for the info crankn, I will look in to that!! everyone has told me tvis makes no difference so Ive never bothered wiring mine up...maybe i should
Al wrote:Mmm, Boost wrote:Interesting, I wonder if my TVIS is actually wired up...does anyone have a link to a page on how to test it?
auch wrote:ok so its vacuum operated thru opening of a negative pressure via electric solenoid...
wow thats pretty good how toyota innovation came up with this method but why do you guys think all manufacturers nowadays have taken the route of variable cam timing instead? i mean aside from the secondary/TVIS butterfly valves creating flow restriction and the fact that the mechanism is alot heavier which promotes more weight and bulkier intake system...
Drifter4ag wrote:basically guys if it aint plugged in then the butterflys are open.
