Brad (Mmm Boost) - did you manage to fix your overboosting problem? You didn't give me your busted actuator did you?
All_Fours wrote:Brad (Mmm Boost) - did you manage to fix your overboosting problem? You didn't give me your busted actuator did you?
Al wrote:Odd. When I turn my boost controller off (actuator controlled boost) I get 7-8psi throughout the rev range and trys to creep up to nearly 9psi above 5000rpm.
BBBrad wrote:Is there much info on this overboost problem, the americans never seem to talk much about it??
Al wrote:Now my exhaust is pretty free flowing, Aussie 3" dp, then a 3" exhaust with 5 mandrel bends then 3" inlet N1 muffler...yet I suffer no overboosting, merely a spike when the TVIS opens up.
All_Fours wrote:fivebob - how would an actuator become too short?
