Oil Pressure and Water Temp Senders
Postby GGnz » Mon Oct 10, 2005 1:39 pm
Just purchased a Oil Pressure and Water Temp guage today but having trouble finding the sensors in my Trueno AE111 Blacktop. Anyone know where abouts these are and if its easy to get to them? Cheers.
GGnz
Postby GGnz » Mon Oct 10, 2005 1:42 pm
Or could be switchs? Not sure of the exact term for it. Some kind of thread.
GGnz
Postby Ae92typeX » Mon Oct 10, 2005 3:13 pm
not sure if it changed for the 20v, but If not, the oil pressure switch is just to the left of the oil filter. water temp above the g'box.
I recall something being discussed about this a while ago, may be in search.
Ae92typeX
Postby GGnz » Mon Oct 10, 2005 3:19 pm
Yeah done a few searches. Went to Auto Electical and they showed my the oil pressure one. Looks like there is alot more involved since it has an "idiot" light attached. Water temp I still haven't found but have an idea of what area its in. Theres just a few others there as well by the looks of it. May need more parts :cry:
GGnz
Postby trueno_20v » Mon Oct 10, 2005 5:58 pm
Water temp is by thermostat housing but facing back, for the water temp sender its best to use this adaptor insted of taking the factroy sensor out Image
ADMIN EDIT: signature too large
trueno_20v
Postby CozmoNz » Mon Oct 10, 2005 11:30 pm
Yup, as said, buy one one of those, cut the radiator hose in half, and fit that sucker.
MAKE SURE YOU HAVE THE SENSOR BEFORE YOU CUT THE HOSE (or buy 2 smaller hoses so you can keep the main one in tact)
Oil pressure youll need to remove the factory idiot light sensor, and fit a virable oil pressure sensor... (ae86's had them, what else has a 4age oil pressure gauge?)
will a 3sge one fit? (the idiot light sensors are pretty small, the gauge style ones are big tanc ones).
Rayne For President!
CozmoNz
Postby NZcelica » Mon Oct 10, 2005 11:50 pm
AE92s had them, AT162s did.
My 3SGE had one (bout 1.5inches in diameter) shouldnt be too pricey from a wrecker.
May I ask where the gauges are going in the car?
ST165 Celica GT-4 <SOLD>
97 GT-T 18psi <GONE>
96 Carib BZ 5 speed
Looking to import a car? PM me
Lots of performance Toyotas forsale. PM me for details
NZcelica
Postby Alex B » Tue Oct 11, 2005 12:00 am
crome cups on teh pillar man :wink:
Postby beeker » Tue Oct 11, 2005 7:00 am
CozmoNz wrote:Yup, as said, buy one one of those, cut the radiator hose in half, and fit that sucker.
If you remove the "factory idiot light sensor" and install a "variable oil pressure" sensor, this obviously gets your Oil Pressure gauge working, but do you then loose your ECU's ability to measure pressure at the same time ? ie safety engine cut on low pressure.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby sergei » Tue Oct 11, 2005 8:17 am
there is no "safety engine cut on low pressure" on most toyotas
Postby CozmoNz » Tue Oct 11, 2005 1:11 pm
i was about to say lol, wtf u talking about.
Ecu cant measure it, because its an idiot light, not a pressure gauge sensor baha :P!.
yeh, chrome cups on the dash bro ;).
*cough*, i suggest you mount them in the din slot... or something alike?
Yeh, its for an mr2, but if you mounted the sterio in the bottom din slot, and put the gauges in the top, they become fairly easy to see (ae111 have a high mounting din / sterio point). Unlike aw11's hahaha.
CozmoNz
Postby beeker » Tue Oct 11, 2005 4:39 pm
sergei wrote:there is no "safety engine cut on low pressure" on most toyotas
AE101 4agze ?
06 RS4 Avant
beeker
Postby GGnz » Tue Oct 11, 2005 10:16 pm
Ive mounted the cups as of today. They are sitting up beside the door. Still a bit of work to be done on the bracket.
Just curious as to that hose adapter. Hows it stop the water from leaking and where can I get em from? And what exactly am I asking for? All I know is its a 1/8" or 1/4" NPT fitting on the water temp.
GGnz
Postby Ae92typeX » Tue Oct 11, 2005 10:41 pm
why would you think the water would leak?
Ae92typeX
Postby GGnz » Tue Oct 11, 2005 10:45 pm
Like how do you make sure the water doesn't leak when putting the fitting it. Remember this is new to me lol.
GGnz
Postby Alex B » Tue Oct 11, 2005 10:47 pm
Empty the water system first and use hose clips :!:
Postby GGnz » Tue Oct 11, 2005 10:50 pm
Do I have to empty it lol. Im completely confused now. Think I might just get someone to do it.
GGnz
Postby Alex B » Tue Oct 11, 2005 10:51 pm
Its simple, empty water system ( probly a bung on bottom of raditor if not remove bottom hose) Put inline adaptor in, hose clip both sides..Put water back in.
Postby Ae92typeX » Tue Oct 11, 2005 10:53 pm
when you put the adapter piece in, cutting the top hose (or swapping for two half length ones) will obvously make some coolant fall out.
really you can do it without draining, but its a good opportunity to renew the collant if you do drain it.
as stated, you need to use hoseclips on the new piece simply so it does not just blow off as soon as radiator becomes presurised as the car warms up.
not a hard job really.
Ae92typeX
Postby GGnz » Wed Oct 12, 2005 8:52 pm
pyro_sniper2002 wrote:crome cups on teh pillar man :wink:
Not chrome but silver :D :wink: :wink:
GGnz
