fuel pump wiring
fuel pump wiring
Postby good ol stoners » Tue Oct 11, 2005 11:57 am
Hey I've done a 20v conversion to my ae101 levin had a 4afe in it.
I had to wire the fuel pump up at the diganostic plug from a 12 v source to get it working. This is currently working from my ignition barrel through a kill switch. So when all the lights are on the dash the fuel pumps running.
This is a bad idea incase I stack the car im going have my fuel pump running still with the engine off which for obvious reason i dont want happening.
Would someone be able to tell me where i could find a wire that has a 12volt feed only when the engine is running? And no power when the engine is not running.
Thanks for any help people can give me
good ol stoners
Postby spencer » Tue Oct 11, 2005 12:49 pm
you need the circuit open relay. Theres a wire from the afm to this so when the afm flaps open and keys on the fuel pump will run. Try a wreckers
spencer
Postby good ol stoners » Tue Oct 11, 2005 3:47 pm
Kool cheers
good ol stoners
