Slotted rotors
Slotted rotors
Postby phat_levin » Tue Oct 11, 2005 4:42 pm
what exactly are slotted rotors? have been thinking about getting some of these http://www.ebcbrakes.co.nz/discrotors/ for my trueno, is there much point? theyr relatively cheap.....
phat_levin
Postby pidge » Tue Oct 11, 2005 4:48 pm
Assuming you've got an ABS equipped Trueno, then you'll have vented disks at the front already. You only need slotted and cross-drilled rotors if you're planning on "taking it to the track". Or insist on driving with absolute disregard to fuel consumption and other road users
i.e. not much point on a road car for braking from 100kmph... (or 130 kmph for that matter)
pidge
Postby phat_levin » Tue Oct 11, 2005 4:58 pm
na not abs, i think that the slotted and drilled rotors would look good underneath my mags tho? i do have a rather heavy foot tho haha
phat_levin
Postby nmemr2 » Tue Oct 11, 2005 5:15 pm
whats relatively cheap?
it will help but only if you really do a lot of breaking, normal driving doesnt build up enough heat to need the extra dissapation (sp)
SW20, a work in progress for 2 years now, all i need to do now is work on it
nmemr2
Postby Mr Revhead » Tue Oct 11, 2005 7:06 pm
get slotted, not drilled, unless you plan on frequent replacement.
this has been discussed at length before
Postby Adamal » Tue Oct 11, 2005 8:43 pm
Slotted Rotors:
Cross Drilled Rotors
Postby phat_levin » Wed Oct 12, 2005 5:17 am
relatively cheap is $136:80 each plus tax for my model....
phat_levin
Postby Leon » Wed Oct 12, 2005 9:35 am
I simply buy standard rotors, and replace them a lot :) I worked out I can get three sets of standard rotors for the same price as one set of slotted.
With the car only being used for competition, my last set of rotors lasted about 18 months (~3,000km or so?)
Postby nmemr2 » Wed Oct 12, 2005 10:48 am
phat_levin wrote:relatively cheap is $136:80 each plus tax for my model....
that is pretty good.
i paid an average 0f $80 for the standard ones i had put on a while ago.
wich i had known that as i would have liked slotted but the price i was given was over $600 a pair for just slotted
nmemr2
Postby AE101_REAR_DRIVE » Wed Oct 12, 2005 12:25 pm
Go to NOPI.COM it's a parts store in the states replacement brake rotors for ae86 onwards made by BREMBO sent to any country dependant on make and model but AE100 series rotors are $40 us each.
http://www.nopionline.com/nopistore/dsp_parts.cfm?vpcid=437&vcatid=0040&vcatyear=1995&vmodelid=040&vmakeid=420&vL1id=0&&vtitle=TOYOTA%20Corolla%201995
Weird site you can buy custom interiors for most cars made already??
Duzn't that defeat the purpose of a CUSTOM interior if any one can buy it??[/img][/url]
Thank God Im Not Silent_Knight Other Wise I Would Have To Kill Myself
AE101_REAR_DRIVE
Postby Stealer Of Souls » Wed Oct 12, 2005 3:00 pm
Slotted useful if you run some of those semi-race type pads too.
I've got Mintex M1166 on the front of my AE85 and they used to squeak a lot when I was just short hop driving.
Since I've had the slotted they squeak less given the same type of driving.
'86 AE85.5 Levin
Stealer Of Souls
Postby beeker » Wed Oct 12, 2005 7:01 pm
Slotted are good, drilled is bad.
Drilled looks bling, but will crack under extreme heat. Technically drilled is also lighter, and thus reduces unsprung weight, but the reality in a road car is it wont make a noticeable difference. I heard (non confirmed), that proper drilled is in fact cast holes, as drilling isn't as long lasting as casting the hole.
Slotted will help extract gas away from the pad under extreme use, and will also skim any glazing from the pad (but will result in slightly more pad wear).
Stick with plain or slotted. Remember, even plain rotors come in a variety of quality, ensure you get some good ones. Try Trade Parts, they have always been good for me.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby phat_levin » Thu Oct 13, 2005 5:42 am
what about dimples as opposed to holes? i see some of the ebc ones have that....
phat_levin
Postby moo^^ » Thu Oct 13, 2005 9:18 am
I use abs+slotted+high temp pads.. it does chew the pad down twice as fast, but it has alot of stopping power.. I have to polish brake dust off my mags every week but i'd still never go back
moo^^
