TRDWGN wrote:Aftermarket ECU and problem all solved....
ROBODISCO_20v wrote:This conversion is quite popular in japan with the MR-S. Basically you get a Lotus Eliese 111R for a fraction of the cost. On BMI touge battles they give the S2000's a run for their money. So would be very interested to see one go into a AE111. You'd give all the VTEC boys a scare for sure
TRD Man wrote:I'd be getting the tape measure out before spending any money.
We had some dealings with the company that built the 2ZZGE powered Echo that you may have seen on the internet.
They were kind enough to tell us all about it and send drawings and photos.
There was some quite extensive chassis mods required to fit the engine in and as we reckon the Echo & Corolla aren't too different here, and the 2ZZGE is a bit longer than a 4AGE, you'd want to check this out before you started.
CozmoNz wrote:uhh, no AE11X with anything that wasnt an A seris engine....
Or it would be a ZE11X.....
As well all know all to well, the first letter denotes the engine class thats sitting in the engine bay.... thus why the SW20 is an SW20... and the ST205 is an ST205, both have 3S-GTE's in them.
EDIT: Typo
