by TRD Man » Tue Oct 11, 2005 5:01 pm
Most AE86 diffs are pre 10/85.
These diffs are the same as TE71.
The later diff has larger axles but I wouldn't say it was the preferred option. In fact I'd say it was the reverse.
1.5 way & 2 way refers to the mode in which the LSD will bind.
1.5 way means it will work fully under excelleration but only half as effectively in overrun or during engine braking. 2 way means it applies equally both ways.
