how to change g series diff to 4 x 114 stud
Postby sk1dlet » Wed Oct 19, 2005 8:13 pm
hey guys im looking at doing a diff conversion in my 82 starlet i have a liteace diff (E series) but is impossible to find an lsd for it, so was thinking of steping up to a G series diff but i'd like to keep the 4 x 114mm stud all round
can ne 1 give me sum suggestions?
otherwise i'll just get the liteace shortened and locked
dylan
sk1dlet
Postby gdsup » Thu Oct 20, 2005 8:30 am
alot of work to fit that E series you sure its worth it?
G series to 4 stud, there are some already 4 stud otherwise you can redrill the 5 stud axles, will prob need to turn down the flange so your disc can slip over to
gdsup
Postby sk1dlet » Thu Oct 20, 2005 6:26 pm
shortening and changing the mounts is not a problem a guy in matamata is going to do it for $500, i don't mind if it's a drum brake rear, as i hav no idea what kinda disc and calliper setup to used on the conversion
sk1dlet
Postby fangsport » Thu Oct 20, 2005 8:45 pm
sk1dlet wrote:as i hav no idea what kinda disc and calliper setup to used on the conversion
cheap cheap, would be to buy some TE71/AE86 discs and fit FXGT or similar calipers .
fangsport
Postby sk1dlet » Thu Oct 20, 2005 9:52 pm
cheers man, does ne1 have a break down picture of what this conversion wud look like?
sk1dlet
Postby sk1dlet » Sat Oct 22, 2005 1:22 pm
ne1 else have sum idea's
sk1dlet
Postby sk1dlet » Sat Oct 22, 2005 5:45 pm
cheers for the links
sk1dlet
