more turbo questions
Postby trdfxgt » Mon Oct 24, 2005 9:34 am
im going to be running my blue top computer for a start until i can afford a aftermarket ecu i have a sx fpr and some 2ltr skyline injectors which ill set up for the feul side of things but how do i set up the map sensor and the timing advance ??
trdfxgt
Postby trd__levin » Tue Oct 25, 2005 3:35 pm
dont do anything till you have the right ecu.
trd__levin
Postby Fraud » Tue Oct 25, 2005 6:22 pm
As above.
Fraud
Postby Punter » Tue Oct 25, 2005 7:57 pm
I know those ^^ probably aren't the answers you wanted, but it makes the most sense if your straped for cash you don't want to explode your motor. just run n/a untill you have your setup sorted.
just my 2 cents anyways :wink:
I love deadlines. I like the whooshing sound they make as they fly by.
Punter
Re: more turbo questions
Postby Bazda » Wed Oct 26, 2005 9:15 am
trdfxgt wrote:im going to be running my blue top computer for a start until i can afford a aftermarket ecu i have a sx fpr and some 2ltr skyline injectors which ill set up for the feul side of things but how do i set up the map sensor and the timing advance ??
fisrt of all you cant run bigger injectors with the standard ecu.
and u want the timing to retard not advance.
Postby JamesM » Thu Oct 27, 2005 12:06 am
u can run bigger injecotrs on the staNDARD computer.and if u use say a 3bar map sensor from the st205? (i forget) but the injectors need to be the same impedance as the standard ones.. it does work. its a cheap arse way to get around aftermarket computer tho. a few guys in the states do it. (its on the net somewhere)
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby Akane » Thu Oct 27, 2005 12:29 am
you can run bigger injectors on standard computer, this trick is for people who's not willing to pay any money for their mods and want big power.
You have to get a lot of paperclips for a start.
You use yoru paperclips and plug it up the injector holes so it wont' inject too much fuel, then you run a length of wire to your cabin to the injectors, now this is the tricky part, when you think the car needs more fuel, you activate the injectors yourself by applying 12Vdc to the injectors, but you have to have a quick hand and good timing.
For the ignition retard, try putting a paperclip inline to each spark plug, the resistance present in each paperclip will cause a delay in firing, hence ignition retard, but you have to have a trial and error to get the correct igntion timing retard, it takes time.
But in saying that, what you do to your car is what you do to your car, I take no responsiblity, although I heard from someone at a pub once that his uncle jack did this and got 450hp, he was running a CT26 too!
Postby Si » Thu Oct 27, 2005 12:32 am
he also had a shiny new muffler that apparrently pulled all the girls 8)
Current: , '96 SubaruImpreza
Si
Postby Bazda » Thu Oct 27, 2005 12:47 am
hey thats something new, i never thoguht u could put bugger injectors in cos it would run rich down low and foul the plugs up. But i suppose that map sensor would help that.
Postby JamesM » Thu Oct 27, 2005 12:55 am
yea it can be done.. i did alot of stuffing around.. but the injectors really need to be exactly same impedance (mine were a bit off and caused me headaches) but as logn as the map sensor is of the same type (0-5V) and reads the same voltage at idle as bluey map sensor then is ok.. but its rough.. i think thats right.. i forget..
is it worth the stuffing aorund? no..
Team Megasquirt
1984 AE86
JamesM
Postby Jebus » Thu Oct 27, 2005 4:04 pm
A jaycar DFA will let ya do Fuel injector swaps, and theyll work sweeto on stock ECU. :D
Jebus
Postby 1598cc » Thu Oct 27, 2005 7:57 pm
put the ecu in cel mode or
get some check valves to your map sensor, and run 2 extra injectors before throttle body..
1598cc
Postby pidge » Thu Oct 27, 2005 9:02 pm
Akane wrote:you can run bigger injectors on standard computer, this trick is for people who's not willing to pay any money for their mods and want big power.
Careful Akane! There's people here who might take you seriously...
pidge
Postby pidge » Thu Oct 27, 2005 9:05 pm
Punter wrote:I know those ^^ probably aren't the answers you wanted, but it makes the most sense if your straped for cash you don't want to explode your motor. just run n/a untill you have your setup sorted.
I vote for this solution. (where's my template rant about "if you can't afford to do it right, you can't to afford to do it at all" when I need it. oh, hang on, I just said it...)
pidge
Postby ants_ae92 » Fri Oct 28, 2005 8:27 am
This is the kind of thing ae-86_lad is talking about.
Although they used 2 bar map sensor and almost double the size of injectors of his standard ones. And this was only light bolt on turbo application.
http://forums.toyspeed.org.nz/viewtopic.php?t=31816&highlight=
Hope this helps.
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby trdfxgt » Fri Oct 28, 2005 11:01 am
ok it seams clear i will need to go to a link strait away but is there not people out there with standed blue tops running psi ?? how are they done
trdfxgt
Postby JamesM » Fri Oct 28, 2005 11:30 am
yes using the cold start injector, computer in diagnotic mode. timing at base 10deg, drove mine like that on 8psi for abotu 1 yr.
Team Megasquirt
1984 AE86
JamesM
Postby trdfxgt » Fri Oct 28, 2005 11:46 am
can you discribe how i get thet injector running ?? as i just find i can learn alot more about this if i do it my self
thanks heaps for any help
trdfxgt
Postby JamesM » Fri Oct 28, 2005 12:45 pm
placing a reisitance.. (use a 5kpot) in series with the sensor signal back to the ecu (engine thinks its colder as u turn the knob (increase resistance)).
Team Megasquirt
1984 AE86
JamesM
