help removing ee80 rear bumper (pic)
Postby EVL20V » Mon Oct 24, 2005 1:43 pm
check out my 30sec top down pic of the rear bumper.
the 2 top circles are the screws joining the wheel arch area
the 2 bottom red circles are possible screws i need 2 remove?
some1 said the bolts unda the caps (blue circles) i undid a couple but i doubt the are for the bumper..?
any help, thanks. :)
EVL20V
Postby nmemr2 » Mon Oct 24, 2005 10:58 pm
remove the screws. if it still doesnt come off then replace screws and look for others that might be holding it on. i know i have about a dozen holding mine on.
and also there are sometimed those little snap on clip thingys that you just have to pull at a little bit
SW20, a work in progress for 2 years now, all i need to do now is work on it
nmemr2
Postby nmemr2 » Mon Oct 24, 2005 11:00 pm
also, with that all said, dont listen to anything i have to say, i have never worked on that car
nmemr2
Postby 4ageman » Tue Oct 25, 2005 10:23 am
Remove the 2 top screw's. Big red circle's. And remove 4 bolt's the blue dot's then slide the bumper back off the car.
4ageman
Postby pervert » Tue Oct 25, 2005 11:09 am
Chances are you'll need to remove the 4 decent sized bolts under the blue caps, usually bumpers run two big mounts into the chassis rails, that then bolt in under the caps, these are the main supports for most bumpers. 8)
pervert
Postby rxtoy » Tue Oct 25, 2005 12:49 pm
if i'm not sure on something i generally start taking apart everything i can see that might be related until it falls off, then put the extra stuff back on. there's not too much back there that could be dangerous to remove, no torque settings or anything. just get into it.
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby EVL20V » Tue Oct 25, 2005 7:06 pm
cheers! :D
EVL20V
