Toyspeed virtual drag race competition. *CLOSED FOR NOW*
Postby RomanV » Tue Oct 25, 2005 9:25 pm
Sweet! Ive been looking for starlet stats like that. 8)
I dont have any time to do any more tonight, well maybe after midnight.
Im taking 'requests' so if you want to see a vtec comparison or whatever, get the stats and I'll do it.
Postby Brick » Tue Oct 25, 2005 9:27 pm
GGnz wrote:I'd love to see some Toyota vs Honda comparisions. Like 20V vs B18c etc.
well that shud be your goal to get all that info, and for it to be fair it shud be B16
Brick
I know Kung Fu
Postby boxxy » Tue Oct 25, 2005 9:47 pm
intereasting to see the rolla is slow in drag and 0-100 times, yet it in the top 3rd for the 2 laptimes... clever little program you got there... im gonna add my other car to see what it will do
Car title/user name:Mighty Mini, Boxxy
(Engine info)
Displacement: 1330
Engine Location: Front
Type: fed by sidedraught :D
(at flywheel)Horsepower@RPM 110@5700
(at flywheel)Ft-lbs of torque@RPM 105 ft/lb 4000 rpm
Compression ratio 11:1
Redline RPM: 7000 rpm
(drivetrain info)
Gears: 4 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.32
2: 2.09
3: 1.35
4: 1.00
Final drive ratio: 3.44
Driving wheels: front
(Chassis and body info)
Car weight in kgs: 650kgs.
front/rear weight distribution: 60/40 ??????
Wheelbase in cms: 204cm
Tire size: 165/60/12
Coefficient of drag: .40
Overall height in cms: 130cm
Overall width in cms: 141cm
Ground clearance in cms: 10cm
1997 Corolla GT.... AGGGHHHHH too many valves
101.5KW atw :D
"Open your throat, we know you can!"
boxxy
Postby fuel » Tue Oct 25, 2005 9:58 pm
Car title/user name: '89 Galant/fuel
(Engine info)
Displacement: 1755cc
Engine Location: Front east/west
Type: N/A 4 cylinder SOHC 8 valve with twin throat carburettor
(at flywheel)Horsepower@RPM 94hp@5500rpm
(at flywheel)Ft-lbs of torque@RPM 106ft-lbs @ 3500rpm
Compression ratio was 9.5:1, now 10:1
Redline RPM: 6250rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: Manual
Gear ratios (below)
1: 3.36
2: 1.95
3: 1.29
4: 0.94
5: 0.76
Final drive ratio: 4.02
Driving wheels: Front
Car weight in kgs: 1050kg
Wheelbase in cms: 260cm
Tire size: 195/60 R15
Coefficient of drag: 0.31
Overall height in cms: 140cm
Overall width in cms: 169.5cm
Ground clearance in cms: 15cm
LOUD NOISES!!!
fuel
Postby RomanV » Wed Oct 26, 2005 12:13 am
Alright, all new cars are in. 8)
For ease of reference, the first post will contain the car times/lists etc.
Postby fangsport » Wed Oct 26, 2005 12:22 am
Car title/user name: TE71 , fangsport
(Engine info)
Displacement:1588
Engine Location: front
Type: NA,
(at flywheel)Horsepower@RPM 120hp@7000rpm
(at flywheel)Ft-lbs of torque@RPM120ft-lbs @ 5000rpm
Compression ratio eg. 11-13:1 :twisted:
Redline RPM: 7,500rpm :roll:
(drivetrain info)
Gears: Eg. 5 speed?
Manual/Auto: manual
Gear ratios (below)
1: 3.587
2: 2.022
3: 1.384
4: 1
5: 0.861
Final drive ratio: 4.3:1
Driving wheels: back
Car weight in kgs: 840kgs
front/rear weight distribution: 54/46
Wheelbase in cms: 240cm.
Tire size: 205/60/13
Overall width in cms: 170cm
Ground clearance in cms: 18cm
fangsport
Postby barryogen » Wed Oct 26, 2005 7:30 am
Thats pretty cool, but I suspect that it is a bit(not much) optimistic on the 0-100 time for me, and a bit low on the top speed(about 30km/h that I know of)
barryogen
2ZZ Guru in training
Postby durty starlet » Wed Oct 26, 2005 8:34 am
haha, now AE85 DJ has some competition
durty starlet
Postby RomanV » Wed Oct 26, 2005 9:17 am
Yeah, its definitely not perferct... There are so many more variables. LSD or not? Sticky tires or not? Good driver or not? etc. etc.
Even the [i]type[i] of tires you run can make a difference.
I would say it probably gets less accurate as the cars get more powerful.
Postby bad20v » Wed Oct 26, 2005 10:12 am
Cheers, Dave. Seems about right for me... 14.8 sec 1/4 mile, seeing as that would be with the full weight of the car taken into account. I have done a 14.7 in reality with the car stripped out so thats fairly close to it. :D Top speed is pretty darn close too as I don't think it could ever get right the way though 6th gear on a standard engine. Even though it has most off its power at the top end of the rev range, I think it would just run out of steam.... but maybe if I had a tail wind.... :P
Yeah!! I rule at Nurburgerking Ring!!! :lol: :lol: :lol:
Thank-You.
bad20v
Postby Snoozin » Wed Oct 26, 2005 10:18 am
Car title/user name: Alfa Romeo Alfasud Ti QV/SnoozinEuro
(Engine info)
Displacement: 1712cc
Type: NA
(at flywheel)Horsepower@RPM125@6000rpm
(at flywheel)Ft-lbs of torque@RPM140lbft@4000rpm
Compression ratio 9.5:1
Redline RPM: 7000rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.545:1
2:2.062:1
3: 1.434:1
4: 1.115:1
5: 0.93:1
6:
Final drive ratio:3.89:1
Driving wheels: FWD
Car weight in kgs: 860kg
front/rear weight distribution:60/40
Wheelbase in cms: 245.5cm
Tire size: 195/50/15 all round
Coefficient of drag: 0.36
Overall height in cms: 132cm
Overall width in cms: 161.5cm
Ground clearance in cms:about 12cm (exhaust has 25mm lol)
Snoozin
Postby fuel » Wed Oct 26, 2005 10:37 am
Car title/user name: '82 TE71 Corolla SE/fuel
(Engine info)
Displacement: 1588cc
Engine Location: Front north/south
Type: N/A 4 cylinder DOHC 8 valve with EFI
(at flywheel)Horsepower@RPM 115hp@6000rpm
(at flywheel)Ft-lbs of torque@RPM 109ft-lbs @ 4800rpm
Compression ratio 9:1
(drivetrain info)
Gears: 5 speed
Manual/Auto: Manual
Gear ratios (below)
1: 3.59
2: 2.02
3: 1.38
4: 1.00
5: 0.86
Final drive ratio: 4.3 I think
Driving wheels: Rear
Car weight in kgs: 900kg
front/rear weight distribution: 55/45
Tire size: 185/70 R13
Coefficient of drag: 0.40
Overall height in cms: 129cm
Overall width in cms: 168cm
Ground clearance in cms: 17cm
LOUD NOISES!!!
fuel
Postby barryogen » Wed Oct 26, 2005 10:57 am
heh, my wifes car :)
Car title/user name: 95Rav4/barryogens wife
(Engine info)
Displacement: 1998cc
Type: NA
(at flywheel)Horsepower@RPM: 130@6000rpm(at flywheel)Ft-lbs of torque@RPM188lbft@4000rpm
Redline RPM: 6500rpm
(drivetrain info)
Gears: 4 speed
Manual/Auto: Auto
Gear ratios (below)
1: 3.938
2: 2.194
3: 1.411
4: 1.019
5: NA
6: NA
Final drive ratio: 4.312
Driving wheels: 4WD
Car weight in kgs: 1180kg
front/rear weight distribution:55/45
Wheelbase in cms: 220cm
Tire size: 215/70/16
Coefficient of drag: 0.4-0.5??? - guestimate as it would probably suck
Overall height in cms: 165cm
Ground clearance in cms: 20.5cm
Should be good for a laugh.
barryogen
Postby HELBND » Wed Oct 26, 2005 10:57 am
Car title/user name: GA70 Supra, HELBND
(Engine info)
Displacement: 1988cc
Type: Twin Turbo
(at flywheel)Horsepower@RPM 207 hp @ 6200rpm
(at flywheel)Ft-lbs of torque@RPM 173 ft/lbs @ 3200rpm
Compression ratio 8.5:1
Redline RPM: ?
(drivetrain info)
Gears: 5 Spd
Manual/Auto: manual
Gear ratios (below)
1: 3.566
2: 2.056
3: 1.384
4: 1
5: .850
6: N/A
Final drive ratio: ?
Driving wheels: RWD
Car weight in kgs: 1460 kgs.
front/rear weight distribution: ?
Wheelbase in cms: 259.5 cm
Tire size: 215/60 R15
Coefficient of drag: .33
Overall height in cms: 169 cm
Overall width in cms: 130 cm
Ground clearance in cms: 14 cm
If anyone can help out with whats missing it would be much appreciated. Have input data for when my W55 box is in. All info off websites provided
HELBND
Postby RedMist » Wed Oct 26, 2005 10:59 am
Alrighty! Lets try the Van Dieman, however I'm summising its in hillsprint trim.
Car title/user name: Van Dieman RF96, Redmist
(Engine info)
Displacement: 1300cc
Engine Location: Mid
Type: NA
(at flywheel)Horsepower@RPM 201.5bhp@ 9750 RPM
(at flywheel)Ft-lbs of torque@RPM 110 @ 7000 RPM
Compression ratio eg. 11.5:1
Redline RPM: 13,000 RPM
(drivetrain info)
Gears: 6 Speed sequential
Manual/Auto: manual
Gear ratios (below)
1: 2.615
2: 1.937
3: 1.526
4: 1.285
5: 1.136
6: 1.043
Final drive ratio: 4.69
Car weight in kgs: 450 kgs.
front/rear weight distribution: 40/60
Wheelbase in cms: 220cm.
Tire size: 205/40 /13
Coefficient of drag: .14 (approx, probably less)
Overall height in cms: 100cm
Overall width in cms: 160cm
Ground clearance in cms: 3cm.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Gadget » Wed Oct 26, 2005 11:14 am
Car title/user name: RZ Supra, Gadget
(Engine info)
Displacement: 2997cc
Type: FI-6 (Twin sequential turbo)
(at flywheel)Horsepower@RPM 350hp@5800rpm
(at flywheel)Ft-lbs of torque@RPM 323lbft@4000rpm
(drivetrain info)
Gears: 6 speed
Manual/Auto: Manual
Gear ratios (below)
1: 3.827:1
2: 2.360:1
3: 1.685:1
4: 1.312:1
5: 1:1
6: 0.793:1
Final drive ratio:3.266:1
Driving wheels: RWD
Car weight in kgs: 1680kg
front/rear weight distribution: 51/49
Wheelbase in cms: 255.0cm
Tire size: FT:235/45/17, RR:255/40/17
Coefficient of drag: 0.33
Overall height in cms: 127.5cm
Overall width in cms: 181.0cm
Ground clearance in cms:about 10cm (legal of course ;)
Gadget
Postby Distrb » Wed Oct 26, 2005 11:53 am
Car title/user name: Ae82 Corolla, Distrb
(Engine info)
Displacement: 1587cc
Engine Location:Front
Type: N/A IL-4
(at flywheel)Horsepower@RPM 170@7800rpm
(at flywheel)Ft-lbs of torque@RPM 130@5600rpm
Redline RPM: 8000rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.166
2: 1.904
3: 1.310
4: 0.969
5: 0.815
6:
Final drive ratio:
Car weight in kgs: 880
Wheelbase in cms: 242cm.
Overall width in cms: 242cm
Ground clearance in cms: 11cm
Distrb
Regular Poster
Postby Emperor » Wed Oct 26, 2005 12:06 pm
hurry up and put my times up there :P
Emperor
Postby RomanV » Wed Oct 26, 2005 1:05 pm
I cant... Dont have enough info.
And I CBF'd searching for the skyline info that your missing. Maybe if it was a toyota, and easy to find.
Postby sleeektoy » Wed Oct 26, 2005 1:36 pm
Car title/user name: Toyota Celica TA22 / sleeektoy
(Engine info)
Type: NA
(at flywheel)Horsepower@RPM132@6200rpm
(at flywheel)Ft-lbs of torque@RPM115lbft@4900rpm
Compression ratio 9.8:1
Redline RPM: 7500rpm
(drivetrain info)
Gears: 5 speed
Manual/Auto: manual
Gear ratios (below)
1: 3.587:1
2:2.022:1
3: 1.384:1
4: 1.000:1
5: 0.86:1
6:
Final drive ratio:4.10:1
Driving wheels: RWD
Car weight in kgs: 960kg
front/rear weight distribution:56/44
Wheelbase in cms: 242.5cm
Coefficient of drag: 0.35 ??
Overall height in cms: 128cm
Overall width in cms: 160.0cm
Old school Celica Nuttr x 3 (collection increased)
昭和49年 トヨタ セリカ LB GT (TA27) :D
昭和47年 トヨタ セリカ TRD(TA22)
昭和52年 トヨタ セリカ LB GTV (RA28)
sleeektoy
