Cylinders 1-2-3-4
Cylinders 1-2-3-4
Postby RomanV » Thu Oct 27, 2005 1:00 pm
When people talk about engines, they often refer to 'number 3 piston leaning out' for example.
Obviously number 3 could be either of the two middle ones, depending on which way around you look at it.
So my question is.... Is piston 1 at the flywheel end, or piston 4?
Postby TRD Man » Thu Oct 27, 2005 2:05 pm
4
TRD Man
Postby RomanV » Thu Oct 27, 2005 2:55 pm
Thanks. 8)
Postby Malcolm » Thu Oct 27, 2005 4:07 pm
yes, you count from the "front" of the engine. Not so easy on a FWD layout, but imagine the engine in a traditional RWD layout and count from the front :)
Postby luvnit » Thu Oct 27, 2005 4:32 pm
so what would number 1 be on an east west format, the left or the right
i want a turbo, why not 2... new car
1993 mitsubishi galant vr4 TT
now with a poked rear diff
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1464 - updated with new car
luvnit
Postby Jebus » Thu Oct 27, 2005 4:35 pm
luvnit wrote:so what would number 1 be on an east west format, the left or the right
The same as N - S
#1 is at the timing end, #4 at the flywheel end
Jebus
Postby fivebob » Thu Oct 27, 2005 4:37 pm
Depends on which way the motor faces :wink:
Start at the accessories end (crank pulley etc) and count to the flywheel end of the motor.
Postby Skidman » Thu Oct 27, 2005 10:18 pm
Piston 1 in all engines (there may be 1 maybe 2 weird ones that i dont know about) is closest to the cam belt/chain,
Hondas are made for people who dont know better.
Skidman
Postby Alex B » Thu Oct 27, 2005 10:37 pm
Thanks, we hadnt all ready worked that out :D
Postby fivebob » Thu Oct 27, 2005 11:10 pm
Skidman wrote:Piston 1 in all engines (there may be 1 maybe 2 weird ones that i dont know about) is closest to the cam belt/chain,
Not always, what about those ones without cam belts or chains, or those that have the cam drive takeoff in the middle of the engine.
Postby method » Thu Oct 27, 2005 11:11 pm
What about a V6 or 8, which one is piston number 1 :lol: :lol:
PICS UPDATED DAILY
method
Postby fivebob » Thu Oct 27, 2005 11:21 pm
method wrote:What about a V6 or 8, which one is piston number 1 :lol: :lol:
That's easy ;)
For most engines, when viewed from the accessories end, left bank is numbered first, then the right bank. So for a V8 the left bank is 1-2-3-4 and the right bank is 5-6-7-8. However a few manufacturers number the right bank first :roll:
Now the real tough one, well tough for those that don't know much about engine history... How do you number the cylinders on a radial engine, or even worse on a piston rotary engine :twisted:
Postby Mr Revhead » Fri Oct 28, 2005 12:04 am
you stamp a 1 where you want and call it ONE. :lol:
Postby AJz » Fri Oct 28, 2005 1:48 am
Mr Revhead wrote:you stamp a 1 where you want and call it ONE. :lol:
and where do you work again :P :P :P
I had vtax :(
AJz
Postby Rob » Sun Oct 30, 2005 11:24 am
In a v6 or 8 the pistons down one side will all be odd numbers and the other will be even
1990 ST185H - project
1996 VS Acclaim wagon
Rob
