Blacktop Pod Filter
Blacktop Pod Filter
Postby mauvis99 » Sun Oct 23, 2005 4:41 am
So to put on a pod on my bzg, i have to put the temp sensor into the pipe, how do i got about that? just put a hole in the pipe or is there some kind of attachment i can buy, thanks.
mauvis99
jst drill a hole
Postby shaggz » Fri Oct 28, 2005 12:34 pm
jst drill a hole and push it in
drive it till it breaks, then upgrade it
Santa Edit: Steve is the former owner of a man-card
shaggz
Re: jst drill a hole
Postby Rick » Fri Oct 28, 2005 5:14 pm
stephen bedford wrote:jst drill a hole and push it in
As above drill a hole, insert the rubber bung from your factory air box and then put in the air temp sensor :D .
Postby blackmk3 » Sun Oct 30, 2005 1:03 pm
my mates just bought a bzr, how have u guys done a cold air box?
Mk3 MA70 Supra
blackmk3
Postby bad20v » Mon Oct 31, 2005 10:27 am
blackmk3 wrote:my mates just bought a bzr, how have u guys done a cold air box?
Here:
Image Image
Waaaaay to easy to make. 8)
Thank-You.
bad20v
Postby blackmk3 » Sat Nov 05, 2005 3:43 pm
thanks heaps!
Mk3 MA70 Supra
blackmk3
Postby Mr. Mainstream » Sun Nov 06, 2005 2:18 pm
BAD20V! u sed you where gona get rid of that damn battery
Current:77 MK2 Ford Escort L 1.3L
75 MK2 Ford Escort L 2.1L
Had: 2X Early Subaru Leggys GT Wags, 1X Subaru RS, 1X 2004 Subaru B4, 2x BFMP Turbo Sedan Famil's, 2x BFMR Turbo Sedan Famil's, AE92 FX-GT, 97 Holden Calais 3.8L
Supercharged 12psi ,Escort, BZ-R
Various Others
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Mr. Mainstream
Postby bad20v » Mon Nov 07, 2005 12:39 pm
Mr. Mainstream wrote:BAD20V! u sed you where gona get rid of that damn battery
Yeah, thats an old pic too. I still haven't moved it yet, I'm still in the process of designing the rest of the intake system at the mo. The BZR's in the workshop at present getting a new clutch pressure plate after I killed the old one at the T vs H Drags. So when I get it back I will be building the new intake system. :D
Thank-You.
bad20v
