edwagon wrote:Percentage. normally around 20-30ish%
UltraSonic2 wrote:yip 20 - 30 % that's what the " car acceleration test " program comes to
GT4 20 wrote:% loss depends on transmission. FWD tends to have the least losses (would also be the same for a car like an MR2) followed by RWD and then 4WD.
From what I understand..
FWD - 17%
RWD - 20%
4WD - 25%
Now bear in mind that the above is a very rough guide.
strx7 wrote:Yes you loose HP between the flywheel and the tarmac, when someone works out a way of being able to TRUELY record what that loss is, let me know. Short of taking, an engine dyno, and bolting it to your axle, its all a guessing game.
it would boil the oil in the gearbox and self destruct very quickly
jondee86 wrote:it would boil the oil in the gearbox and self destruct very quickly
Which is why race cars have have transmission and differential oil coolers
as well as engine oil coolers. There is a limit to how much heat that can
be dissipated from the surface of the gearbox/diff. More power means
more heat and more surface area is needed to stay within the temperature
range of the oil.
Cheers...... jondee86
jondee86 wrote:Short of taking, an engine dyno, and bolting it to your axle, its all a guessing game.
This is exactly what the DYNAPACK chassis dynamometer does. Eliminates
tyre pressure, alignment and roller slippage losses.
more heat and more surface area is needed to stay within the temperature range of the oil.
fivebob wrote:UltraSonic2 wrote:yip 20 - 30 % that's what the " car acceleration test " program comes to
Which is a complete load of crap
FWD - 17%
RWD - 20%
4WD - 25%
Very rough and IMHO still way too high, might be close to correct for a 100hp car, though the figures I've seen quoted are 15%-FWD, 17%-RWD & 22%- 4WD
"The efficiency of a manual transmission drive train can be closely
estimated by multiplying together the efficiencies of each loaded gear pair
or other working mechanism of the complete drive train. For helical gear
gears used in transmissions in an EV at torques averaging 20% to 30% of
max and with a low loss lubricant, the efficiency should average around
0.97 per gear pair. An allowance is needed also for the other operating
but unloaded gear pairs, since they are resisting by some friction and
continually churn the lubricant. An 0.99 factor is considered adequate for
these unloaded gears. The Fiesta 4 speed gearbox then, which uses
but one gear pair at a time, under these conditions has an efficiency of
0.97 x 0.99 or 0.96. Counting the differential drive, another helical gear
pair and 0.97 factor, the motor-t-drive axle efficiency becomes 0.93.
Manual transmissions typically used in front engine rear axle drive cars
(those with 1:1 ration for "high" gear) are connected "straight through"
and load none of their gears when in "high". Efficiency then averages
about 0.98, with the moderate 2% loss going into the unloaded but
lube-churning gears. In the lower gears, however, these "straight
through" transmission must use two helical gear pairs, so the gearbox
efficiency alone becomes about 0.97 x 0.97 = 0.94.
There are still more drive train losses before power reaches the driving
wheels. While constant velocity U-joints are low-loss devices as are ball
or roller bearings, considerable and frequent angularity changes (such as
in front-drive axles) cannot be achieved without considerable sliding and
rolling friction losses. 2% loss, or 0.98 efficiency, is reasonable for
modern front drive axles, (including the bearing and seal losses). For
front engine, rear drive cars, a 1% allowance for drive shaft u-joints is
adequate (if joint angularity is small) and another 1% for typical axle
bearings and seals."
You can break down the drive train efficiency like this:
Typical modern front-drive transaxle (Civic, Fiat 128, Fiesta, Rabbit)
Manual transmission
Number of loaded gear pairs 1. (0.97)
Allowance for idling gears: lube churning plus extra bearing and
selector drag (0.99)
0.97 x 0.99 = 0.96
Differential Drive
Helical gears (0.97)
Drive Axle
(0.98 )
Overall Efficiency
0.97 x 0.99 x 0.97 x 0.98 = 0.91
Transaxle with bevel gear axle (VW Beetle, Renault LeCar)
Manual transmission
0.97 x 0.99 = 0.96
Differential Drive
Bevel gears (0.96)
Drive Axle
(0.98 )
Overall Efficiency
0.97 x 0.99 x 0.96 x 0.98 = 0.90
Typical rear drive (not 1:1) (Chevette, Datsun 210, Pinto)
Manual transmission
Number of loaded gear pairs 2. (0.97 x 0.97)
0.97 x 0.97 = 0.94
Drive Shaft
(0.99)
Differential Drive
Hypoid gears (0.89)
Drive Axle
(0.99)
Overall Efficiency
0.97 x 0.97 x 0.99 x 0.89 x 0.99 = 0.82
As above but in 1:1 "high" gear
Manual transmission
Number of loaded gear pairs 0.
(0.98 ) Allowance for idling gears: lube churning plus extra
bearing and selector drag
Drive Shaft
(0.99)
Differential Drive
Hypoid gears (0.89)
Drive Axle
(0.99)
Overall Efficiency
0.98 x 0.99 x 0.89 x 0.99 = 0.85
ROBODISCO_20v wrote:fivebob wrote:UltraSonic2 wrote:yip 20 - 30 % that's what the " car acceleration test " program comes to
FWD - 17%
RWD - 20%
4WD - 25%
Dude you're splitting hairs here, you're saying GT4 20 is wrong then you're saying the almost same thing
jondee86 wrote:Here ya go.... this is a pretty good explanation of how to figure
transmission losses."The efficiency of a manual transmission drive train can be closely
max
Of course, none of this matters a toss if all you want to do is measure what improvement your tuning or mods have produced. Just use the same dyno and overlay the results. The only thing that you need to
measure is power/torque at the driving wheels.
