AE85.6 wrote:i know the sound is cool and all but i dunno if i do get the 20v if i should or just keep the intake and modify to face the front ?
BZG|Bling wrote:how it looks.....
got filters and shes all go!!!![]()
relocated the battery and air temp sensor, removed all factory airbox ducting / resonator box and plan to have some new ducting in place when I get time.
I now have 2 'redundant' air lines, both of which were plumbed into the factory plenum (pictured below)
from what i've read, one is a vacuum hose and the other ISC hose (whatever that is)
my question is this, do I need to filter these hoses, or do they not require filtering?
chur chur
bad20v wrote:And again... just a wee idea:
eightytrueno wrote:those stock ones didnt seal properly around the intake manifold even with gaskets, bzgbling i'd be careful of that on yours!
AE111_modifier wrote:bad20V That is awesome!!!!!! is it your car? Did that set up gain extra KW's? That is one sexual engine!
BZG|Bling wrote:cold air would be sorted if you cut a hole in your bonnet and add a scoop obove the filters
anyone got a cheap one for sale?
bad20v wrote:Its just a picture I found off the net awile back. Besides this setup was from a AE86 so it was a NTH/Sth facing engine.
