4age internal socket for head bolts (FOUND)
All the Frequently Asked Questions which are of a technical bent. Look here before posting a tech query.
Postby oldskool_rwd » Wed Nov 02, 2005 4:17 pm
does any 1 in chch have a 4age internal socket to get the head bolts of my 20v cos no 1 seems to knw were to buy 1 of these even toyota couldnt help me
thanks
oldskool_rwd
Postby crnkin » Wed Nov 02, 2005 4:21 pm
go to repco its called a t50
deaf_homo "currrently yes"
crnkin
Postby IH8TEC » Wed Nov 02, 2005 5:26 pm
are you sure? if they are the same as the 4agze, when i did mine i just used a normal socket, except it was not 5 sided it was the one with more. 10m from memory
Postby QikStarlie » Wed Nov 02, 2005 5:31 pm
a trox (spelling?) bit will fit
QikStarlie
Postby 86 Power » Wed Nov 02, 2005 5:33 pm
You just need a 12 point socket. a small one like 1/4" drive or 3/8" drive. Small enough to get in there.
86 Power
Postby fivebob » Wed Nov 02, 2005 5:40 pm
If it's an internal headed bolt then it's not a Torx bolt, it's a 12 point spline, also called a triple square.
Postby IH8TEC » Wed Nov 02, 2005 5:44 pm
thats what i was thinking , and you'll find it should be metric, mine were 10mm
Postby oldskool_rwd » Wed Nov 02, 2005 6:31 pm
yo i got the tool its called a t55 internal socket got it from ripco
any1 else got that problem just go to ripco (repco lol) and get the t55 tool its just a 1/2 inch drive so can go on strong arm bar
oldskool_rwd
Postby fivebob » Wed Nov 02, 2005 6:56 pm
I've never heard of Toyota using Torx pattern for head bolts, Searching on the net indicates that the tool required is the same as the one for the 3S and I know ituses 12 point spline.
So while a T55 torx bit may fit, it is probably not the right tool for the job and in reality is no better than using an allen key, in fact it's probably worse.
Torx bits have the wrong tooth profile and are only 6 point, the bolts in question shold be 12 point.
Anyone got a picture of the bolt in question so we can identify the correct tool for the job.
Postby pidge » Wed Nov 02, 2005 8:10 pm
The Blacktop ROM mentions a 10mm double-hex socket in its list of required tools.
pidge
Postby QikStarlie » Wed Nov 02, 2005 8:54 pm
yeh the torx bit isnt the right tool. but fits pretty good and does the job. would be alot better than a allen key
QikStarlie
Postby fivebob » Wed Nov 02, 2005 9:20 pm
QikStarlie wrote:yeh the torx bit isnt the right tool. but fits pretty good and does the job.
About as good a job as a surgeon using a rusty razorblade compared to a scapel. Which would you prefer?
Guess again, it's the wrong size, the wrong tooth profile and at best would point load the bolt, at least the allen key will work on the face of the cutout and spread the load far better than a Torx driver :roll:
Still the question asked was what is the right tool, not what is the next best thing and the answer to that is a 10mm 12 point spline/double hex/triple square, not a Torx bit or for that matter an Allen key.
Postby QikStarlie » Wed Nov 02, 2005 9:57 pm
umm yeh i did say it wasnt the right tool.
yes the 12 point hex (or what ever you may call it) is the right tool. i have one for my 4e and 5e. but since its a diffrent size and the torx is easyer to come by. i brought the torx bit witch did the job. for a one off it works.
i could state that he, or no one for that matter. asked what the right tool was. but im not that picky...
i'd say more like a surgen using a fresh stanley knife blade. still works, but you just need a bit more skill :D
QikStarlie
Postby fivebob » Wed Nov 02, 2005 10:56 pm
QikStarlie wrote:i'd say more like a surgen using a fresh stanley knife blade. still works, but you just need a bit more skill :D
Nah, an Allen Key is more like a Stanley knife, the Torx is definitely a rusty razorblade :wink:
As can be seen from these drawings the Torx driver is a poor fit, whereas the Allen key is much better (though still not the right tool)
Image Image
Postby QikStarlie » Wed Nov 02, 2005 11:03 pm
meh, fair enough. im just happy that 20v thing is long gone
or does that mean dudes who use torx bits, are pretty dam skillfull. or just like doctor nick, i guess...
QikStarlie
Postby fivebob » Wed Nov 02, 2005 11:16 pm
QikStarlie wrote:or does that mean dudes who use torx bits, are pretty dam skillfull. or just like doctor nick, i guess...
Just lucky I guess, if the bolt was siezed then I can imagine the oaths being uttered at those who said that the Torx bit was the right tool for the job.
That said, I'd liken anyone who sells you a Torx bit for this job to Dr. Nick. Then again the average Ripco employee isn't the sharpest knife in the draw :lol:
Postby Mr Revhead » Sun Aug 13, 2006 10:18 pm
ok after a wee search i refound this thread again
can we FAQ it please
Postby Dell'Orto » Mon Aug 14, 2006 5:06 pm
And I can tell you that Koken do tools specifically for removing Toyota headbolts...also available from the not so bright lads at Repco ;)
Edit - thanks sark.inc, the link to the correct Ko-ken tool
http://www.koken-tool.co.jp/catalog/en/ ... _head.html
Return to Technical FAQs - General
