Right, at the point of putting coilovers into the rear of my Starlet with the TA63 diff setup. What I need to know is what the approximate factory angle for the rear shocks is so we can copy this with the new turrets that are going in. Current plan is to cut the front towers from a spare KE70 and use them in the rear of the Starlet/Carina floorpan, just need to set the approximate angle we want for them.
If any one else has installed coilovers into their car, would really appreciate any pics you can share. Need to get this sorted before the car can go away to get the cage installed.
Callum
