1JZ VS 1UZ
1JZ VS 1UZ
1JZ
14
45%
1UZ
17
55%
Total votes : 31
1JZ VS 1UZ
Postby Destroyer » Thu Nov 03, 2005 5:00 pm
witch is the cooler motor?
IF YOUR READING THIS...
YOUR FINISHED READING...
Destroyer
Postby Mr.Phreak » Thu Nov 03, 2005 5:42 pm
For what?? 1UZ makes a better coffee table than the 1JZ :D
Mr.Phreak
Postby Alex B » Thu Nov 03, 2005 5:51 pm
mr phreak is correct, the jz would simply fall over.
Postby mr pad » Thu Nov 03, 2005 5:54 pm
pyro_sniper2002 wrote:mr phreak is correct, the jz would simply fall over.
From laughing?
mr pad
Postby Silent Knight » Thu Nov 03, 2005 5:58 pm
They'd both still be at a bit of a lean depending on the location of the sump. :?
Maybe if you do a high performance twin sump conversion where they're the same size at each end you'd be able to balance it perfectly. No more coffee spils. :D
Silent Knight
Postby Destroyer » Thu Nov 03, 2005 6:14 pm
so the uz would be better as a coffee table, and i guess it would be a better boat anchor too
Destroyer
Postby Mr.Phreak » Thu Nov 03, 2005 6:39 pm
I'd rather cast iron over alloy for an anchor, but thats just me.
Mr.Phreak
Postby bad20v » Fri Nov 04, 2005 10:46 am
Ummm... depends on the size of the lounge it is place in. If the area is quite big and square shaped, the 1UZ would be my choice but if it is to be placed in a more narrower area, say between two couches, I would say the 1JZ would fit better.
Don't ya think?
Personally I think that a 2JZ would be alot better opinion with the twin air-conditioning blowers hooked up to the side, providing warmth in winter. :lol:
8)
Thank-You.
bad20v
Postby Alex B » Fri Nov 04, 2005 12:41 pm
If the room was big enough you could always use a 1gz-fe, make a nice stand for it and you would have the hella coffee table.
Return to Polls
