Ae101 Fuses
Ae101 Fuses
Postby lotstodo » Fri Nov 11, 2005 5:43 pm
Can someone tell me which fuse is for the central locking/electric windows in a trueno ae101? It all stopped working, i know i have a dodgy switch and am picking up a new one but the central locking normally worked... Could it be something else other than the switch or fuse?
Cheers.
lotstodo
Postby Silent Knight » Fri Nov 11, 2005 5:44 pm
If it's a fuse then the fuse box cover that you take off will tell you on the inside which fuse is for what. Just turn the cover around and have a look inside...
Silent Knight
Postby lotstodo » Fri Nov 11, 2005 5:50 pm
Thanks, but have had a look at all boxes and couldnt figure it out, doesnt say
anything about central locking or windows :(
lotstodo
Postby Silent Knight » Fri Nov 11, 2005 5:50 pm
Which one's did you look at?
The one in the driver side kick panel will have the fuses you are looking for...
Silent Knight
Postby lotstodo » Fri Nov 11, 2005 5:56 pm
Yup looked there, only got half a label which doesnt help - guess ill test them all :(
lotstodo
Postby slighty_sykotic » Wed Dec 21, 2005 12:37 pm
Same problem here, and the label on the box doesnt help at all. There is nothing related to ethier of the locking nor windows/sunroof.
Did you find it?
--Sykotic
slighty_sykotic
Postby Silent Knight » Wed Dec 21, 2005 1:56 pm
Have a thorough search on the Internet...somewhere there will/should be a picture of the sticker that should be on the inside of the fusebox as a reference.
I found all the Soarer ones on the net easy peasy so I suspect for a 101 it should be even easier since allot more people have them...?
Silent Knight
Postby aesc » Wed Dec 21, 2005 3:15 pm
If its the fues then why dont you just take out all the fuses in that fuse box until you find a blown one and replace it. If there is no fuse blown then the problem lies elsewhere
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Ako » Wed Dec 21, 2005 3:20 pm
aesc wrote:If its the fues then why dont you just take out all the fuses in that fuse box until you find a blown one and replace it. If there is no fuse blown then the problem lies elsewhere
Don't be stupid, that would be far too straight forward!
Ako
Postby GTCRSHR » Wed Dec 21, 2005 3:43 pm
on a similar note ....
why would the central locking only Half work ? (tried to close but it just wont )
solinoid rooted ? i have oiled the bars to no avail
Nothing to see here ...
GTCRSHR
Postby aesc » Wed Dec 21, 2005 3:57 pm
Yeah well you'd think so :roll:
EX AE101 owner
2013 Ford Focus ST
aesc
Postby slighty_sykotic » Wed Dec 21, 2005 9:30 pm
Im not that stupid... All fuses have all been checked. All are fine, im asking if the thread starter found out the problem.
--Sykotic
slighty_sykotic
Postby demis » Wed Dec 21, 2005 9:55 pm
if your swithc is $&#$% then it probally wont work as in normally dosent work without it pluged in, even when you can use other things like your key to unlock all the doors if the switch isnt pluged in they dont work
so maby you just need a new switch
EX 1984 Corolla FX GT (AE82) 1st gen 4age
EX 1996 Corolla BZ touring (AE101) 5th gen 4age -LSD
EX 1997 Carib Z touring (AE111) some 4afe muck
Ex 2000 Fielder S (ZZE122)- Its BIG RED
2002 Corolla Ts (ZZE122) Mr ~ Ts
demis
Postby slighty_sykotic » Wed Dec 21, 2005 10:24 pm
nah, it will still work without switch. My alarm is wiring directly into the central locking not far below the switch, and to figure out the wiring i had it all to peices and the switch off, and it would still lock and unlock by ethier the alarm, or shorting to pins from the switch plug with a screwdriver. So theres simply no power getting there.
--Sykotic
slighty_sykotic
Postby lotstodo » Wed Dec 21, 2005 11:06 pm
I did eventually find it (or the auto electician did) it was up under the dash, way up... it was just a $10 fuseable link.
lotstodo
Postby slighty_sykotic » Wed Dec 21, 2005 11:13 pm
Damit, i was kinda hoping it wasnt a silly fuse in the middle of nowhere.
Thanks for that though, save me tracing it back that far.
--Sykotic
slighty_sykotic
Postby slighty_sykotic » Mon Dec 26, 2005 9:45 pm
Found it, its about 10cm above in-cabin fuse box. I don't know what its meant to look like, cause mine was a really rangy *lets make a fuse from a mini blade fuse and solder two wirers to it and jam it in the sockets*....
But its all good now.
For future reff, its not the manuel nor labeled....
--Sykotic
slighty_sykotic
Users browsing this forum: Bing [Bot] and 26 guests
