4AGZE Oil Pressure Gauge
Postby beeker » Sun Nov 13, 2005 8:20 pm
4agze (from AE101)
I want to hook up a Oil Pressure gauge, but dont want to loose the factory light / and am told ECU engine shutdown on low pressure (true ?)
Here is a pic of below the car looking up. Is the sender with 5N on it the pressure sender ? (assume yes)
What about the unused/plugged hole to the left of it ?
If it has a factory Oil Pressure sender, can I simply get an Oil Pressure gauge that can also use this same sender ?
I'm a novice on this topic, so all help appreciated.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby evil_si » Sun Nov 13, 2005 8:50 pm
that plugged hole is the block water drain.
yes the sender with 5n on it is the switch for the dash light,
the ecu wont shut the car down for low oil pressure.
if you buy a brass T you can run both off the same pressure port,
or else just run the guage, as with a guage you wont need the dash light.
evil_si
Postby beeker » Sun Nov 13, 2005 9:21 pm
evil_si wrote:that plugged hole is the block water drain.
best place 2 get a brass T ?
06 RS4 Avant
beeker
Postby ATAl » Sun Nov 13, 2005 9:53 pm
A lot of people reckon a t peice will break off fairly quickly with the vibrations from the engine, resulting in a large oil leak.
ATAl
Postby sergei » Sun Nov 13, 2005 10:21 pm
don't do brass, do it in S/Steel, try engineering supplys like Blackwoods/Paykel, or hydrolic hose places...
Postby matt dunn » Sun Nov 13, 2005 10:38 pm
Brass is fine if you remote mount it,
but then you have to also earth the brass.
I'd still remote mount it depening on the size of your gauge sender if it is electrical not mechanical
Matt
Postby Barks » Sun Nov 13, 2005 11:22 pm
I ditched the factory sender on my AE92 GZE and went with a remote mounted electrical sender. No problems at all.
BTW: Do the AE101's only run an oil light and not a pressure gauge like the 92's did?
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music"
Kristian Wilson, Nintendo, Inc, 1989
Latest rides: 2004 Avensis Wagon, GT Avalanche 1.0, GT Avalanche 0.5, Marin Toscana CX
Barks
Postby matt dunn » Mon Nov 14, 2005 12:10 am
Barks wrote:I ditched the factory sender on my AE92 GZE and went with a remote mounted electrical sender. No problems at all.
Yes. AE92 have gauge only from factory ( most)
So you will have no light?
Postby beeker » Mon Nov 14, 2005 6:08 am
So if I remote mount it, who can make me up the high pressure flexible piping ? Recommendations ?
Sorry, new at this.
06 RS4 Avant
beeker
Postby FLAWLES » Mon Nov 14, 2005 11:17 am
theres another way around this problem
go to the buy a autogauge filoter neck " i call them "
basicly wot it is is it has four ports in them to run oil temp oil pressure and stuff
you take ur oil oil filter off and put this item on screw a new oil filter on and wam bam thank u mam there u go
still retains the factory oil light
ive don this but im running a oil cooler to
FLAWLES
Postby mr pad » Mon Nov 14, 2005 11:24 am
FLAWLES wrote:go to the buy a autogauge filoter neck " i call them "
So it screws into where the oil filter goes? Got any more info?
mr pad
Postby FLAWLES » Mon Nov 14, 2005 3:09 pm
it looks like this. the big blue thing in the right hand cnr
i think from memory toyota has the 3/16 plug fitting
http://www.autogauge.com.tw/web/product ... rysubid=33
FLAWLES
Users browsing this forum: Google [Bot] and 28 guests
