QW1KGT Boost Cut at 12 pounds
Postby qw1kgt » Tue Nov 15, 2005 6:35 pm
No doubt this problem is pretty common with manual gt starleys... Whats the most common way of dealing with this?
qw1kgt
Postby Silent Knight » Tue Nov 15, 2005 6:37 pm
Get the boost cut removed or don't run so much boost...
Silent Knight
Postby qw1kgt » Tue Nov 15, 2005 6:48 pm
thanks mate. thats kinda the problem. I have no idea how to remove the boost cut thing... I could run less boost, but that would be gay. reckon?
qw1kgt
Postby Silent Knight » Tue Nov 15, 2005 6:50 pm
You can go with an A/M ECU or just a stand alone unit with the sole purpose of removing boost cut.
There's lots of places that makes units like those...HKS, Greddy etc etc
Silent Knight
Postby qw1kgt » Tue Nov 15, 2005 6:58 pm
OK, sounds like the ticket. So, where do I find one of these things? A/C ECU? excuse my lack of knowledge Jedi. I am but a young apprentice...
qw1kgt
Postby Silent Knight » Tue Nov 15, 2005 6:59 pm
A/M ECU means aftermarket which is expensive if you just need boost cut removed.
Go for a small stand alone unit with the sole purpose of removing the cut. Have a search on the HKS and Greddy etc websites it should be listed there with full details on how they work.
Silent Knight
Postby qw1kgt » Tue Nov 15, 2005 7:03 pm
thanks dude. I will do that. I was hoping you would say something like "you pull this wire out and solder the green wire to the flux capacator..."
I guess there is no easy fix wivout spending more dough..
Thanks once again for the quick replies. This forum is quite good!
qw1kgt
Postby Silent Knight » Tue Nov 15, 2005 7:25 pm
Silent Knight
Postby qw1kgt » Tue Nov 15, 2005 7:34 pm
cheers dude. legend. :D
qw1kgt
Postby 1598cc » Tue Nov 15, 2005 8:03 pm
removing the boost cut with a Fuel cut defender will make it run lean past 12psi.. not a good idea.. there are other ways around fueling above 12psi without a standalone ecu tho.
1598cc
