I haven't had a chance to study one working just yet. But looking at
the valve on a non-running engine, there is a small bolt that goes in
backwards so that the head rests against the knob on the valve. A jam
nut goes on the other end to hold the setting. Since it is a vacuum
actuated valve, the knob will retract when the engine is running.... and
the only time it will be all the way out is when there is no vacuum =
engine not running.
According to the instructions for a similar valve on a carbed 4A-F you
set the valve by adjusting your idle to 1400 rpm on a WARM engine with
the vacuum hose to the valve DISCONNECTED from the valve, and
blanked off (poke a small bolt or similar in the end of the hose). This
stops air leaking into the manifold and raising the idle.
Then reconnect the vacuum hose, and the knob on the valve should
retract and the idle should drop to 800 rpm.... assuming all other idle-up
systems are OFF.
Two things.... since it will be difficult to set your idle properly with the
Auxiliary Air Valve stuck somewhere between open and closed, do as
someone else suggested... block off the hole in front of the throttle
butterfly with a rubber plug. Then use the idle adjustment screw.
Second thing.... when the engine is off, the vacuum operated valve
should be capable of holding the throttle butterfly slightly open (after
you have adjusted the small bolt). If it can't do that, then none of the
above is worth a pinch of s**t !!!! I'll check a runner in the weekend
and let you know
Cheers.... jondee86
