Hello,
Can someone please point me to the location of the Tensioner for the Handbrake? It seems there is a little too much travel to pass a warrant.
Thanks
Rasker
All_Fours wrote:you need to take the back wheels off, unbolt one of the rear caliper bolts, swivel the caliper up and wind the piston out a bit. Sometimes you can do it with needle nose pliers but you're better off getting a caliper adjustment tool from repco or somewhere. Then you just wind it out as far as you can and still get the caliper back over the pads, then do the other side.
All_Fours wrote:adjusting pistons does help
fivebob wrote:if you had to manually adjust them then there is something wrong in your caliper, probably siezed threads.
