Rick wrote:do you have a factory loom or are you making your own?
fangsport wrote:the mani loom from the engine runs through the firewall, behind heater duct/A/C unit and into the ECU under the main heater box. there is also a partial loom from ECU that heads into the main dash loom behind heater controls.
fangsport wrote:headlight wiring runs from drivers kick panel through wheel well and into enginge bay via inner guard.
is this a road car rebuild or for competition use???
Cahuna wrote:There is also wiring going from the passengers kick panel through the passenger wheelarch, for things like windscreen wipers, aircon etc.
If you can hang out until the weekend you are welcome to come over and have a look at the wiring in my AE92 rally car - the loom in it is still pretty much complete and you can see exactly what runs where as there isn't much to the dashboard at all (car is at the panelbeaters at the moment though, so can't do it before the weekend)
