shortening struts
Postby wde_bdy » Wed Nov 23, 2005 5:32 pm
Incorrect Mr Pervert. :wink:
They can be cut if the ends from the factory are plain and unground and no heat is used OR they may be modified by a recognised spring manufacturer as long as the ends are reshaped to factory configuration.
Not generally worth it though when you can get custom wound springs pretty cheap.
Callum
wde_bdy
Postby pervert » Wed Nov 23, 2005 5:38 pm
purple_beasty wrote:Incorrect Mr Pervert. :wink:
Callum
So if it's a standard style spring (like in a KE70 for example), with one flat and shaped end and one normal end of the spring, you can chop coils off the normal coiled end...and make certification?
I'm kinda confused... :D
pervert
Postby wde_bdy » Wed Nov 23, 2005 8:04 pm
Download the PDF from LVVTA, $&#$% have protected it so I can't copy text. :evil:
But basically what you said is correct. If both ends are tapered then a spring maker has to do it. But for the cost of cert, unless you have lots of other stuff getting done you might as well just get custom wound springs.
Callum
wde_bdy
Postby pervert » Thu Nov 24, 2005 7:46 am
Yeah, I wasn't planning on doing it anyway, it's just so I don't go spouting off incorrect information again... :wink:
pervert
Postby Fraud » Thu Nov 24, 2005 2:42 pm
I have cut springs and a cert. (Yes they were passed)
As purple beasty said, if they are shaped etc on the end, must be matched if shortened.
Fraud
