d2 adjustables
d2 adjustables
Postby jener8r » Wed Nov 23, 2005 12:01 am
does anyone here have a set of the d2 adjustable suspension in their car?
we put a set into my boyfriends ae85 and we found that when you wind the coilover just below half way the springs are no longer captive! has anyone else had this problem? we got some keeper springs but aparently d2 are going to re-design this model or lengthen the springs so that they are captive
jener8r
Postby Ako » Wed Nov 23, 2005 9:50 am
Or....
You wind the part you've wound down, back up again, and adjust the height seperately as its designed to be done...
Ako
Postby jener8r » Wed Nov 23, 2005 10:14 am
how do we do that? i dont get what you mean
jener8r
Postby Ako » Wed Nov 23, 2005 10:30 am
I dont know about the AE85/6 ones, havent seen a set myself. I have a set for a VR4 here in front of me, and the height can be adjusted seperately from the spring seat height but winding the whole assembly down into the mount itself - if that makes sense.
Ako
Postby jener8r » Wed Nov 23, 2005 11:37 am
you mean at the very bottom? you cant do that with the ae85/86 ones because you have to use some of the original parts, the d2 shock sits in the part the original one goes in so you have to take the original out, theres no way of winding it up or down! bugger aye
jener8r
Postby Bazda » Wed Nov 23, 2005 4:51 pm
get some keeper springs, its what most coil overs come with
Postby jener8r » Wed Nov 23, 2005 5:35 pm
yeah we have got some, just that you'd kinda think if you're going to pay $1800 for suspension it would be all legit!
jener8r
Postby Bazda » Wed Nov 23, 2005 5:43 pm
you payed $1800 for it!!!!!!!!!!!!!!!!!!
god damn
Postby gdsup » Wed Nov 23, 2005 6:57 pm
Ako wrote:I dont know about the AE85/6 ones, havent seen a set myself. I have a set for a VR4 here in front of me, and the height can be adjusted seperately from the spring seat height but winding the whole assembly down into the mount itself - if that makes sense.
the ae86 type d2 are different to this, im sure someones got a pic of the kit to post up, I would be cautious of this setup
gdsup
Postby jener8r » Wed Nov 23, 2005 9:17 pm
yeah they weren't cheap!
jener8r
Postby Bazda » Wed Nov 23, 2005 9:34 pm
jener8r wrote:yeah they weren't cheap!
D2 as in the puple ones??
Postby jener8r » Wed Nov 23, 2005 10:23 pm
yeah and they got the adjustable damper, camber, height and preload etc.
http://www.redlineperformance.co.nz/mai ... =2&pid=260
jener8r
Postby Bazda » Wed Nov 23, 2005 10:26 pm
agh
You could get them much cheaper else where for like $1k
Postby gdsup » Wed Nov 23, 2005 10:34 pm
the rears aren't height adjustable are they ? and the fronts are a sleave that sits on top of the standard platform? with a standard lenght insert that drops into the front strut body...
gdsup
Postby jener8r » Wed Nov 23, 2005 11:17 pm
yep you got it. hahah oh well they're my boyfriends he paid for them, i told him he could probably get them cheaper but he had to have them then and there. his problem! and they say females are impulsive!
jener8r
