4age/ze Oil pressure sender leak?
Postby lil » Thu Nov 24, 2005 8:12 am
Just wondering if the oil pressure sender on 4age/ze's are known to leak.
I have an oil leak around that area on my mr2 and the sender unit looks like it may be the culprit, although it is hard to tell as the airflow under the car is obviously speading the oil around a bit.
I have recently replaced rocker cover gaskets, distributor O'rings, camshaft and crankshaft oil seals so these shouldnt be the problem.
Any thoughts?
lil
Postby Ae92typeX » Thu Nov 24, 2005 10:24 am
when you replaced the dist o'rings- did you replace both the outer and inner ones?(you suggest you did, but just checking). Sometimes, on the inner one the shaft wears a notch in it and prevents the new seal from actually working.
just a thought anyway.
Ae92typeX
Postby lil » Thu Nov 24, 2005 10:51 am
yeah replaced both dizzy seals
lil
Postby pidge » Thu Nov 24, 2005 12:40 pm
Well, my AE101 GTZ developed a leak in the oil pressure sensor switch.
Get it fixed before the leak damages the "fan" belts.
pidge
Camshaft seals
Postby andyztouring » Thu Nov 24, 2005 6:38 pm
check the camshaft seals ,one of my Levins dribbled oil big time,I thought it was the oil sender unit(hard to get a good look)but it was the camshaft seals,it seems to send the oil to the front of the engine.These seals will leak badly if fitted slightly off straight.May pay to look there first.
andyztouring
