GZE Fuel Pressure
GZE Fuel Pressure
Postby CAMB01 » Sun Nov 27, 2005 9:45 pm
Hey all, just want to know what the base fuel pressure is at the fuel rail on a 4AGZE?
Also what would be a good pressure to set it to? as i have an adjustable fuel pressure regulator.
Cam
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Ako » Mon Nov 28, 2005 4:39 pm
Good pressure to set it to - The stock pressure. I dont know what that is though, someone else will fill you in on it. Approx 48psi is the norm for most cars (from memory) though. Only reason to change it is a) upwards for a last ditch attempt at getting more fuel if you're stretching to it, or b) downwards if you have big injectors in and dont want to tune it too far out with an s-afc.
Ako
Postby Adydas » Mon Nov 28, 2005 5:41 pm
isnt he asking to find out what the stock pressure actually is?
Adydas
Postby CAMB01 » Mon Nov 28, 2005 6:59 pm
Adydas wrote:isnt he asking to find out what the stock pressure actually is?
Your right i am but that information is useful.
CAMB01
Postby l1ttle_d3vil » Mon Nov 28, 2005 7:16 pm
standard pressure for a 4age bluetop is approximately 35PSI + or - a couple, not sure if it would be any different for a ZE though.
Postby Drifter4ag » Mon Nov 28, 2005 10:23 pm
bluetop 2.55bar
redtop/ze - 2.9bar
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby CAMB01 » Tue Nov 29, 2005 6:46 pm
Thanks people :)
CAMB01
