ae111 BZR electrical problems... please help!
Postby Knob City » Tue Nov 29, 2005 10:17 am
hey all, well last week my electrics $&#$% out, I have no rev gauge, speedometer, indicators, heater, windows.
I do have the stereo though, which cuts out sometimes.
and my lights still work and so do my hazards.
its not a fuse problem as ive checked every fuse about 4 times, even tested each one with a new fuse.
thanks in advance.
Knob City
Postby B1NZ » Tue Nov 29, 2005 6:01 pm
has the stereo been recently put in? sounds like it may be the cause
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Knob City » Tue Nov 29, 2005 9:28 pm
nope factory stereo.
jump started the car, let it sit there for a while, went for a drive to charge the battery up and it started stuttering under any load what so ever, just got home at it sounded like a (censored) rotor lol.
felt like it was running out of gas, which it wasnt because i even went down and got some in a container and tried it all over again, it would idle for a bit then slowly die.
Knob City
Postby GGnz » Tue Nov 29, 2005 11:01 pm
$&#$% sounds like a serious problem. ECU maybe?
GGnz
Postby Mr.Phreak » Tue Nov 29, 2005 11:06 pm
Dodgy Earth?
Mr.Phreak
Postby GGnz » Tue Nov 29, 2005 11:08 pm
I'll start unplugging fuses, cutting wires tomorrow and get back to you :lol:
Yeah right. I'd check all your earths and ur ECU. You'd think a fuse might of blown though.
GGnz
Postby Alex B » Tue Nov 29, 2005 11:37 pm
Tis not ECU it has no effect on the indicators etc, id be looking at earthing problems.
Postby Ae92typeX » Wed Nov 30, 2005 12:10 am
as well as earths, also check relays and it could be worth getting the battery and alt checked also. being season change, its a typical time batteries begin to fail, and a non charging battery will cause some of those issues listed. I once had an alt $&#$% out and do very similar things whilst still not getting a warning light on the dash.
Ae92typeX
Postby matt dunn » Wed Nov 30, 2005 12:20 pm
pyro_sniper2002 wrote:Tis not ECU it has no effect on the indicators etc, id be looking at earthing problems.
When an alternator plays up indicators are sometimes one of the first things that stop,
and since you have jump started it...
Get the charging checked.
Postby Knob City » Wed Nov 30, 2005 1:28 pm
have taken it to work (but a battery jump pack on it) and they will sort it out hopefully.
Knob City
