20valve with aftermarket ECU - problem..
Postby EVL20V » Fri Dec 02, 2005 5:57 pm
ok,
silvertop 20valve. running a link V4.
wired up using MAP & TPS.
problem = sitting idling, plant the foot or even just 1/2-3/4 force and it bogs and farts and hesitates and then once past 2500rpm its mint :lol:
possible solutions? - injectors wiring? run it 100% TPS? ignition?
NOTE: has just had full tune and ecu rewire, so timing/mixture etc all sweet. but #@$@#% if we know y it does that. how can this be fixed?
ALSO - how is ur 20v with aftermarket ECU wired up? and with link?
cheers people :)
EVL20V
Postby ChaosAD » Fri Dec 02, 2005 6:00 pm
wot gas u using?
ChaosAD
Postby EVL20V » Fri Dec 02, 2005 6:12 pm
95, but try to use 98, wouldnt be that at fault would it, as once over 2500rpm she flys 8)
its in an 85 corolla sedan, fuel pressure is sweet aswell. :?
sucks trying to drive away but she bogs and i hold up the traffic, sometimes it stalls :oops: go the 4000rpm gentle take offs :lol:
EVL20V
Postby Bazda » Fri Dec 02, 2005 6:35 pm
ur problem is link
Postby EVL20V » Fri Dec 02, 2005 7:02 pm
Bazda wrote:ur problem is link
is that supposed 2 b funy? :twisted: :lol:
wot part is wrong?
EVL20V
Postby Bazda » Fri Dec 02, 2005 7:05 pm
hehe
i dont liek link that much lets put it that way, seen to many cars with problems.
Maybe u need this special thing for the map sensor cos u got quads and and does something to the signal and makes it smoother, cos apparantly its not smooth
Postby EVL20V » Fri Dec 02, 2005 7:50 pm
chuckd some 98 in b4 and 99% solved.
will changing from 2 filters (1 for pair of throttles)
to factory intake box/plenum fix anything? apart from colder air :D
EVL20V
Postby atmosports » Fri Dec 02, 2005 8:05 pm
The problem is not with Link or their products, it's with all the cowboys & idiots out there fitting & tuning them that don't know what they are doing. I should know as I get to fix everyone $&#$% ups with Link's. Their new Linkplus G2 is on a par with a Motec M400 at less cost.
Anyone who slags Link obviously either doesn't know what they are doing or else was got a poor install or tune. I know of several 700hp+ skyline gtr's running Linkplus, numerous 500hp+ wrx's & evo's on early plug in LEM's. The year Possum won the goldrush he run a Linkplus. The majority of problems with Link are not to do with the product, hence the reason why Link is slowly going back to having Dealers again & only selling to them as they'll now the product & know how to use the new Link stuff
atmosports
Postby trueno_20v » Fri Dec 02, 2005 8:06 pm
Hey just wondering how much it was for your link + install and tune also who installed/tuned it? What sorta power atws was it? Is your silvertop turbo or something? cheers
ADMIN EDIT: signature too large
trueno_20v
Postby RedMist » Fri Dec 02, 2005 8:13 pm
atmosports wrote:The majority of problems with Link are not to do with the product, hence the reason why Link is slowly going back to having Dealers again & only selling to them as they'll now the product & know how to use the new Link stuff
I always thought that selling direct was an idiotic move from Link. Great way to get little product support and piss off your dealers all in one move.
For the fault at hand, I'd be looking at map signal, the first accl enrich zone or if its been PCLink tuned with an early version at some stage, it will be TPS only. (bug in the code) You'll need to download a later version and reset the field... oh and if your attempting to use an old saved map ensure you record 100 fuel and ign as the new version doesnt convert it correclty.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby vvega » Fri Dec 02, 2005 8:35 pm
Bazda wrote:hehe
its called a acumulator
the blacktops have them installed at factory
its not just link that has this issue
any map drivin ecu will have dificulty if you dont have a stable map signal
:D
vvega
Postby EVL20V » Fri Dec 02, 2005 8:38 pm
cheers ears :)
EVL20V
Postby 10k 20v » Sat Dec 03, 2005 1:44 pm
it could also be where you're taking the map signal from.
You need to take it from the idle passage, thats the top chamber on the intake manifold that the quads screw on to.
I had no problems at all with my link.
It all depends who's tuning it. I think the biggest problem with novice's is the understanding of interpolation, cold start and accel inrichment.
10k 20v
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
