4AGE fly wheel
4AGE fly wheel
Postby blue-smoke » Sun Dec 04, 2005 3:12 pm
on a silver top 4age what presusre should you put on the bolts holding in the flywheel , thanks
blue-smoke
Postby Grrrrrrr! » Sun Dec 04, 2005 5:32 pm
according to the toyota manual for the blacktop
75Nm, which is 54ft-lbs
Grrrrrrr!
Postby AE85.6 » Mon Dec 05, 2005 1:04 pm
how differnt is that to a 16v ?
just got me thinking cause when my clutch arrives and i swap gearbox etc i am replacing my 16v flywheel with a 20v one, which setting would i use i assume the 20v ???
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby CAMB01 » Mon Dec 05, 2005 8:55 pm
The bolt torque is the same 75Nm or 54ft lb.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Punter » Tue Dec 06, 2005 9:53 am
Thanks guys I needed to know that too,
would anyone also know the torque for the front pulley of a silvertop?
I love deadlines. I like the whooshing sound they make as they fly by.
Punter
Postby Grrrrrrr! » Tue Dec 06, 2005 7:01 pm
the crank pulley bolt should be tightened to 101 ft-lbs.. also known as 140Nm, again, this is from the blacktop manual but they should all be the same as far as i can see.
Grrrrrrr!
Postby AE85.6 » Tue Dec 06, 2005 7:09 pm
sweet cheers guys
AE85.6
Postby asleep » Tue Dec 06, 2005 8:50 pm
sup mate ur camshaft timing pulleys (the top 2) should both be set to 60nm, or 43 ft-lbs, and as above ur crankshaft pulley (the lowest one) should be at 140nm, or 101 ft-lbs
asleep
