IBC not controlling boost
Postby GT4PWA » Wed Dec 07, 2005 2:58 pm
My Gizzmo IBC is suppose to be cutting the boost out at 10psi but its letting it go higher until the boost cut kicks in at about 11psi.
Its beginning to get rather annoying have you guys got any ideas on what could be causing the problem?
And does anyone know these and could take a look?
GT4PWA
Postby Ako » Wed Dec 07, 2005 3:09 pm
The GIZZMO IBC doesn't cut boost at any pressure. All it does is control a solenoid to the a duty cycle you set it to. There is no feedback loop - it doesn't care if its running 10psi or 20, its just doing the simple job its asked to do.
Ako
Postby GT4PWA » Wed Dec 07, 2005 3:28 pm
Are you sure? It used to hold at 10 before i got my drive around engine now it dosn't hold 10 psi and keeps climbing higher
GT4PWA
Its a electronic gage and controller
GT4PWA
Postby Ako » Wed Dec 07, 2005 4:18 pm
I'm positive, I sell the things.
All it is - and since you have one, you should be familiar with how to work it - is a device which can have a number of settings for pulsing a solenoid.
Yet, it acts as a boost gauge, but it doesn't monitor the boost level as such. Try playing with the duty cycle, and seeing if the problem is still there.
Ako
Postby GT4PWA » Wed Dec 07, 2005 4:22 pm
ok cheers thanks for the help
GT4PWA
Postby Adydas » Wed Dec 07, 2005 4:48 pm
maybe somethings leaking and causeing it to be un stable.
Adydas
