Stupid cam swap question..
Postby Ako » Thu Dec 08, 2005 10:20 am
Ok, dumb question here.
Engines sitting on the ground, cambelt and everythings all off, (its a 3sgte), but I cant get the f%$%ing cams out! In a nutshell theres that big metal plate which is being a pain. I cant get the bolt holding the cam gear to the cam undone (theres no way to brace the thing and stop it moving), and can't get to the last couple of bolts holding the cam in place because of said metal plate.
Any ideas? I'm --><-- this close to just cutting the bloody plate up!
Ako
Postby Malcolm » Thu Dec 08, 2005 11:04 am
the camgear bolts really have to come off (pays to do this before removing cambelt ;) )- otherwise maybe you can unbolt the inner cambelt cover (I think this is the big metal plate you're having problems with) enough to access the last two cam retainer caps
failing that, cut off the inner cambelt cover and contact me about a replacement :D
Postby Ako » Thu Dec 08, 2005 11:30 am
Yeah... Kinda occurred to me somewhat late that I probably needed the cambelt still on to get the bolts undone.
Out come the tin snips tonight :lol:
And I have a spare cover thingy.... Luckily ;)
Ako
