1ge to 1ggte conversion help please
Postby MrDori » Thu Dec 08, 2005 12:20 pm
Need help to fing wiring diagrams guys,
Donor car is a gz20 soarer 1987, projest is gx61 mark II 1983.
Any help would be mint with anything to do with conversion, i.e flywheels, clutch set ups etc.
Thanks a heap mike
MrDori
Postby Ae92typeX » Fri Dec 09, 2005 1:57 am
is the gx61 manual already?
assuming its manual, box and standard clutch will be fine (although an uprated clutch wouldnt hurt) When I did my ga70 manual conversion I didnt have any probs with a na clutch setup anyway.
wireing wise for the 1ggte go here:
http://members.optushome.com.au/mkhala/ ... index.html
Has articles for diagrams and ecu pinouts which should help, but if you are taking from a donor car it should be a straight (albeit a little time consuming) swap...well sortov
Ae92typeX
Postby Boldy » Fri Dec 09, 2005 7:46 am
Boldy
Postby Adamal » Fri Dec 09, 2005 8:13 am
Recently helped HELBND replace his 1GGTE with one from a Cresidia into his Supra.
Not sure if the Supra and Soarer are similar, but we had to change the sump on it, due to the cross member.
Postby MrDori » Fri Dec 09, 2005 8:24 am
Cheers for those wiring links, unfortunatly they do not match up with the ecu i have, i beleive mine is a generation 2 1ggte anybody got any for this one?
ive got a w57 gearbox, wondering how the 1geu flywheel is gana hold up?
Anymore help is great!
MrDori
Postby UTERUS » Sat Dec 10, 2005 6:59 pm
anyone?
UTERUS
Postby Gx71man » Sun Dec 11, 2005 5:54 pm
MrDori wrote:Cheers for those wiring links, unfortunatly they do not match up with the ecu i have, i beleive mine is a generation 2 1ggte anybody got any for this one?
Umm clutch, yer get one for the flywheel you have got..... just get a heavy duty LUK clutch or summint, find out the clamp pressure's and the highest one wins.
as for the wiring http://www.toymods.org.au/ Tech docs, As boldy has said.
1ggte gx61 sounds good im glad the mx/gx/rx series is getting popular.
I Give My Mrs A 1/4 inch at a time, For those ten seconds or less Im Free...
Gx71man
Postby MrDori » Tue Dec 13, 2005 11:01 am
yea those ecu pinouts dont mate up tp my ecu? what parts of the wiring am i gana need? theres 3 plugs coming off the main loom that i have to fing out what they are for
MrDori
Postby HELBND » Tue Dec 13, 2005 11:04 am
hey mate if youre in auckland, feel free to come have a look at the supra if youre having trouble seeing where plugs etc go... pretty sure all mine are back in the right place :lol:
HELBND
Postby MrDori » Wed Dec 14, 2005 9:54 am
Cheers man, i have a whole soarer so thats no a problem.
Anyone swaped a 1ge for a gen2 1ggte?
MrDori
Postby AE25 » Wed Dec 14, 2005 10:00 pm
i was going to suggest www.sixworks.com.au as they have alot of the wiring diagrams but the site seems to have dissappeared
http://thermactor.com/forum/viewtopic.p ... f3a73fb715
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
