Changing Inner CV
Postby CozmoNz » Fri Dec 09, 2005 10:31 pm
REAL?!
so its just the nut on the bottom of the shock?!
go take pix! im going for a 200km drive tomorrow!!!
Rayne For President!
CozmoNz
Postby Fred » Fri Dec 09, 2005 10:39 pm
dont know how to post pictures.
it was the bolt that holds the shock insert in place so that it doesnt wobble inside the base.
The bolt thing sits at the base of the nice shiny shock leg, mand dont know how to explain need to host a pic or something
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Fred
Postby CozmoNz » Fri Dec 09, 2005 10:44 pm
e-mail to cozmo_nz@hotmail.com ill host it
i do know what your talking about, pix dont hurt though
i really really dont want to crawl under my car in this weather :D
CozmoNz
Postby IH8TEC » Fri Dec 09, 2005 10:58 pm
its quite simple cozmo, if you've seen a the struts in your car, or ever changed shocks that have inserts in them, you'll know, as i'm sure you should. holds the top of the insert centrally at the top.
when i brought my car, i used to always have a bad knocking metal on metal noise going over bumps. i looked for ages, then eventually put it down to shocks, (this is the front by the way)
so we took them out, brand newish kyb shocks, bu some dickhead had hacksawed off that bottom bowl thing that holds the bottom of the shock centrally in the strut, then on the top nut, VERY DODGILY, welded a smaller spacer in the one that screws into the strut 8O . so the top of the shock was alwas moving in the strut and banging all the time
all in all it would've lowered it an extra 5-10mm, and f#cked a perfectly good set of shocks
so replaced them new kyb inserts, got rid of 95% of the noise, then found needed bump stops in there, nows its smooth as. car was supposedly professionally lowered too.
some people :roll:
Postby Fred » Fri Dec 09, 2005 11:06 pm
mand thats dodgy, least u found it before something bad happend was just frustrating cause was looking everywhere for something loose and it just wasnt something i expected
Fred
Postby CozmoNz » Fri Dec 09, 2005 11:42 pm
That nut?
As lloyd gave me the image :D thank you hrt!
CozmoNz
Postby IH8TEC » Fri Dec 09, 2005 11:52 pm
yip
Postby Fred » Sat Dec 10, 2005 4:32 pm
sure was the lil bugger, wow and i even used the right tool to tighten it haha
Fred
