Do different oil filters affect oil consumption
Postby guy » Sat Dec 10, 2005 12:00 am
Hi, just wondering... do different oil filters affect the amount of oil that your car eats. I normally use those repco oil filters and I would normally have to top up on oil maybe once every oil change (8000 km). But recently I used a FRAM oil filter and now my car loves the chomping on the oil now and I have to top up around every 1000 kms.
I use magnatec by the way... on the might 20 valve!
guy
Postby CozmoNz » Sat Dec 10, 2005 12:02 am
oh god.. quick, delete what you just typed out!
your starting something beyond what you think your doing!
*hides*
Hint, just use geniune ;) Mr Toyota Knows best!
Rayne For President!
CozmoNz
Postby RedMist » Sat Dec 10, 2005 7:24 am
CozmoNz, That wasn't very helpful now was it.
Yes, Oil filter's do consume oil. They have a carbon catylicic content (CCC) which generally removes about 500ml per 1000km. However there are different ratings and different oil consumption rates. The rate is printed on the cartridge, generally embedded in the part code.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Type of oil
Postby andyztouring » Sat Dec 10, 2005 8:48 am
Have you changed brand of oil,some brands will use more than others,usually Castrol will drink oil like its going out of fashion try a different brand of oil,often will use less oil.
andyztouring
Postby FLAWLES » Sat Dec 10, 2005 9:41 am
as dumb as it sounds
oil filters have there own flow rates i.e 22.5cc etc
you can effect the oil pressure buy putting a diff size filter on a car
good example of this is a hydraulic system on a tractor
u put a small filter on it and it effects the hydraulics ie they go realy really slow
but if u do the op and put a bigger filter on they work way faster
same applies with oil filters
just do wot cozmo said and stick with gen and change oil to like a protec " castrol "
FLAWLES
