Water pump reliable life on 4agze
Postby beeker » Sun Dec 11, 2005 10:14 am
how many km's should a water pump live for reliably on a 4agze.
Seems like some manufacturers change them as a disposable item at ~100,000km
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby vvega » Sun Dec 11, 2005 10:30 am
sounds good to me
and just fo info ...
toyota ones are one of the cheapest you can get :d
v
v
vvega
Postby peas » Sun Dec 11, 2005 10:53 am
And come with the back plate... unlike some aftermarket ones. If you are running a larger crank pulley pays to bear that in mind too. When mine came off it was quite badly pitted and I was told that the probable cause was that the pump was being overdriven and cavitating. Usually just replace it with timing belt etc so 100km sounds about right.
'97 Caldina GT (ST215G)
peas
Postby evil_si » Sun Dec 11, 2005 10:53 am
well at $41 for an aftermarket one,
they cheap enuf to do at any stage
its hard to guage how long they will last for, some may last forever and a day, some maybe just a day.
evil_si
Postby Mr Revhead » Sun Dec 11, 2005 12:03 pm
the thing to watch with aftermarket ones is unlike the toyota ones they dont come with the backing plate or the gaskets/orings.
and often its the orings that will leak....
Postby gdsup » Sun Dec 11, 2005 2:09 pm
i have found on a gze the impellor (sp) shaft seal is the weak point, probably bescause the higher load from the s/c, the previous owner of my went through 3, but ive never had a problem since ive had the car
gdsup
Postby Mr Revhead » Sun Dec 11, 2005 4:57 pm
maybe they were running the belt too tight?
Postby sergei » Sun Dec 11, 2005 10:03 pm
also make sure you running coolant mix, not just water, as coolant will lubricate seals better than water, in my opinion the most cases of leaking water pumps are because of people run just water (same goes for bhg, blocked radiators, jammed theromstats)...
Postby Drifter4ag » Mon Dec 12, 2005 12:33 am
i just run water ... brown water at that ..
ive never changed the water pump ...
its done about 100000kms with me driving it with track time .. its no longer been running the fan stuck on the end of it ...
but i would say the toyota genuine pumps are safe as houses !!!
A+ would defnintely trade with toyota again
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
